Re: 93 idiling wierd
Start with the idle control valve, give it a good cleaning.
Originally Posted by franky_402
My 93 3.8 bird is idiling a little wierd sometime when i start the car it will jump to a little over one and be fine stay at that rmp and idle, sometimes it will jump to 2.3 when starting then drop to about 1 and be fine and other times it will start at about 1 and then the rpm's will jump all the way down and shake the car almost dieing(sometimes does) and go back up to 1 back and forth for about 10 seconds and then be fine. Also sometimes it will crank for 3 seconds and start sometimes and soon as i turn the key to crank it starts almost instantly. I am absolutely stumped dont know where to start at all!!!
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
