Old 08-28-2006, 09:45 PM
lancer07 lancer07 is offline
Question need help
well finally got my car running with the swap. DOHC ZC with pm6 ecu. heres the problem. it starts up fine, gets to operating temp, and then just dies. you guys have any ideas on what could be causing this. need help asap so i can start driving the beast
real name:Nik
i posted in yours now go post in mine
Old 08-29-2006, 11:07 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: need help
First reaction should be to check for shorts in the wiring, and do a complete tuneup.
Cap, rotor, check all sensors, test or replace coil, test or replace igniter module, plugs, wires, (if you haven't already).
Throwing any ECU codes?
When it shuts off, can you still crank it?
It just won't start, right?
