Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-28-2006, 09:37 PM
eggfarmer eggfarmer is offline
Post what part next?
Time to get mustang ready for smog testing.Car started running rough (like on 2 cyls) after driving approximately 10 miles. Bought a scanner and had 2 code -- TPS and EGR-- replaced both items; car still had same symptoms. Did tune up -- cap,rotor,plugs and so forth. Same troubles;measured coil -- primary was 1. ohm, secondary was 9.3. any thoughts or suggestions would be appreciated. ( I forgot to mention-- 1988 2.3l FI) Ok, new day another dollar.Replaced ICM and ign coil,made no differance other than started acting up quicker. Decided to give it a day of rest (the car and myself).
Old 09-03-2006, 01:52 AM
NJH_Habitatpro NJH_Habitatpro is offline
Send a message via AIM to NJH_Habitatpro Send a message via Yahoo to NJH_Habitatpro
Re: what part next?
check vacuum hoses. I cant spell. you know what i mean.
Old 09-03-2006, 09:54 AM
Re: what part next?
Thanks for the input,but unfortunately I've all ready checked and re-checked everything under the hood.I went back to the basics and you would be surprised with what I have found.Today I go one more step and I think the trouble will be gone.
Old 09-03-2006, 11:47 AM
Re: what part next?
Ok well just sayhing cause like you i have checked and re checked everything like you say. Went back on a hunch just to replace some of the vacuum hoses. That was the problem. But lets hear what you got when your done.
Old 09-04-2006, 05:11 AM
johnwads johnwads is offline
Re: what part next?
hey let me know what you find mine is running rough too and sometimes acts like its not getting enuff fuel? got any ideas on that one?
maybe i'll check and start replacing some vacuum lines.. i know i have one that seesm to have oil in it.
Old 09-06-2006, 09:44 PM
Re: what part next?
well, took the car for a ride.Ran GREAT till it warmed up (about 3 miles), started sputtering (holding back) when pedal was applied. noticed some oil on throttle plate shaft so now i'm thinking valve stem seal bad and fouling plug(s) on accelleration (idles with no problem).find out tomorrow.
Old 09-07-2006, 06:52 PM
Re: what part next?
forget the valve stem seal idea (bad pcv), but drove down the road and back,ran great till I parked and let it idle. Started running really rough. Hooked up scanner again---no codes? got to feeling around moving things---nothing? Shut it down and restarted--- ran for 1 1/2 hours w/just a slight miss? Not making much sense
Old 09-07-2006, 07:04 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: what part next?
If you have the firing order correct... except turning in the opposite direction on the distributor cap, it would be running on two cyls.
Old 09-24-2006, 11:32 PM
scottngio scottngio is offline
Re: what part next?
check your catalyc converter had same problem with my mitsibishi only had problems on hot days or after it warmed up on cold days ran great.
Old 09-27-2006, 10:33 PM
Re: what part next?
don't know what happened, the car is running great now, passed the smog test with the best numbers I've seen for this car since I've owned it. Time to sell though,looking at a NICE T-Bird.
