Go Back   Automotive Forums Car Chat > Mitsubishi > Mighty Max
Old 08-28-2006, 09:36 PM
Mohave's Avatar
Mohave Mohave is offline
Won't Start ECU rebuilt
I had my 92 Mighty Max suddenly quit, as if the key had been turned off. I traced through it and found no spark. Replaced the coil with no effect. Read up on the problems with the ECU and had mine rebuilt. Still no spark.
The fuel pump relay clicks and I am wondering what to check next. Is there an ignition cutoff in the event of fuel pump failure? Any suggestions are appreciated.
Old 09-05-2006, 12:33 AM
CivMoeEJ8 CivMoeEJ8 is offline
Send a message via AIM to CivMoeEJ8
Re: Won't Start ECU rebuilt
check out www.mightyd50.com
Old 06-18-2011, 06:19 PM
Mohave's Avatar
Replaced the ECU again today and it is running after 6 years.
