Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 08-28-2006, 08:31 PM
i8uiky i8uiky is offline
ac not working
the low side pressure is in the hundreds and the high side is way to high to(cant remember the exact numbers). the low side hose is verry hot aad the high side hose is worm. what is going on? do you think it could be a restriction in the high side?
thanks in advance
i8uiky
Old 08-28-2006, 11:53 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: ac not working
if you have too much freon or too less freon the A/C will not operate correctly, Either drain or refill accordinly.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 08-29-2006, 10:42 PM
Re: ac not working
I only added a half a pound and I pulled 30 inches of vacuume first.
Old 08-30-2006, 08:10 PM
carlos80 carlos80 is offline
Re: ac not working
Get proper pressure readings. System pressure will be over 100 psi with compressor off when on, the low side will show 35 to 45 and high anywhere from 175 to 250. Why did you evacuate and recharge the system in the first place? Did you make sure it held vaccum for at least 10 min before recharging it?
Old 08-30-2006, 11:04 PM
Re: ac not working
I didnt evac and recharge the system we just bought it and the ac didnt work.
today I found a restriction in the high side and removed it I am going to flush and refill the system tomarow.
Old 09-02-2006, 07:41 PM
Re: ac not working
I filled my system now I need a sweater.
thanks
i8uiky
