Old 08-28-2006, 06:26 PM
AutostradaVR4 AutostradaVR4 is offline
Rear brake conversion :feedback:
Im wondering about changing the rear brakes on my 1993 VR-4 to the gen 2 setup (from single-piston, flaoting caliper to 2-piston rigid; also bigger rotors). Has this been done before? anyone got a link to a more info on it?
How hard would it be, what would i need, what would i need to do, and would it be worth it?
thanks guys
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 08-28-2006, 08:00 PM
Igovert500's Avatar
blue + red light magnet
Re: Rear brake conversion :feedback:
You will need 2nd gen calipers/pads and rotors, that's it as far as I've ever heard. You might have to bend/grind the dust shields, but other than that, hte swap should be fairly easy if you have ever done any brake work.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-28-2006, 08:31 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Screw the dust shields, they just get in the way. Remove em.
Old 08-28-2006, 09:18 PM
Ralliart 3000gt's Avatar
Ralliart 3000gt Ralliart 3000gt is offline
yea it was done to my car.........
Old 08-28-2006, 10:08 PM
cool. good to know its possible, has been done, and is whithin my mechanical ability...
but
...do you guys think its really worth the work, time, and green?
Formerly BlinkRA182
Old 08-29-2006, 03:06 AM
Igovert500's Avatar
Eh, that I can't tell you. I mean it's obviously an improvement, and if you get used calipers from a partout...ALOT cheaper than a Big Brake Kit. However, obviously it also isn't as good as a Big brake kit. Time it would take I don't really consider, nor work, because I don't ever look at mods as a chore....although if I were doing it, I'd also throw on some SS braided brake lines, all new fluid, and paint the calipers, etc. If you are gonna do it, why not go all out. As I said, it would be an improvement, I just don't know how much, so it's hard to say if it's worth the money. I know plenty of NA guys have swapped on 1st gen vr4 brakes and noticed a difference...but fewer have done the swap you are talking about, and I don't recall if any of them mentioned it was noticeably better. Personally if I could locate all the parts cheap, I don't see why not. Plus you could probably sell your old first gen stuff to an NA guy looking to upgrade. If you look for a 2nd gen vr4 part out you could find calipers cheap. I saw this group buy going on rotors and SS lines (you could even get colored lines), awhile back. If you sold your old stuff to pay for the calipers and a bit towards the lines, you already would have to replace the rotors and pads at some point in teh future, so it's only like you would be spending part of the price on SS lines in the long run.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-29-2006, 08:59 AM
yea, i was planning to do slotted rotors, Axxis Ultimate pads, SS braided lines, and Motul 600 fluid. Already got caliper paint kit...just waiting to get time to do it. I got the conversion idea when i was shopping around for stuff. Im on a pretty tight budget, so the Big Brake upgrade is definitely out of the question. I didnt think of looking for calipers in a partout though, thats a good idea! Doing that, I just might be able to finance this conversion successfully! Thanks for the help.
1 last question. Does anyone know if the rear 2nd gen calipers are bigger than the front 1st gen ones? Im concerned about wheel clearance, because my front calipers are already damn close to the wheel, so if the rears will be bigger, the conversion is obviously not an option for me.
Formerly BlinkRA182
Old 08-29-2006, 03:16 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
if you're looking for SS braided brake lines, IPSmotorsports.net has the best deal on them. the brake lines made by Techna Fit are the cheapest, they're DOT approved. only reason they're cheaper is b/c when you order them, the company makes them for you, then ships it to you, so it will take a few days to get to you, but it works out in the end for the tight budget people. i'm putting mine on, and i'll let you know what braking difference i feel.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-31-2006, 09:54 AM
ChrisGood's Avatar
ChrisGood ChrisGood is offline
Do this, buy new lines, braided of course. Pick up a set of speed bleeders, these make the job a little easier when diy. I know it can be done without but why risk any amount of air. Go buy the calipers and rotors for a 2nd gen at an auto parts store. They will cost you but you get a core exchange, return the cores from your car.
Call this a money saving route. You get good rebuilt calipers real cheap. Hell you could even throw some money at a set of slotted rotors (helps with heat).
I can fix anything, if you just tell me how.
White 2006 Chrysler Town & Country
Zurich Pearl White 1993 3000GT VR4
1993 3000GT VR4
Old 08-31-2006, 12:41 PM
Linebckr49's Avatar
i guess he could do this. the Auto Zone ppl might not realize that his calipers (1st gen-single piston) aren't a perfect match (2nd gen-2 piston). risky, but you could try it.
93 3000GT base
Old 08-31-2006, 06:33 PM
hmmm...i didnt realize Autozone did core charges on calipers...
sounds like a pretty good idea though.
Formerly BlinkRA182
