Old 08-28-2006, 06:23 PM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
mpfi swap problem
just put the mpfi on my sohc zc but the car will not satrt it will just turn over abd you can smell the gas but that is about it.i have checked and recheck the wires but everything seems fine.any ideas what i should check. is the zc dizzy wired the same way as the si dizzy cause i could only fine wiring for the si dizzy and then the dohc zc but i got the sohc. used lots of the si conections so evrything should have matched up fine but i dont know beging to hate the mpfi swap.
Old 08-28-2006, 06:35 PM
Re: mpfi swap problem
also i have been hearing all sorts of ecu i could use with the sohc zc but i would likr to know for sure witch one i should use i got the pg7 but i dont know if this is the right one for this motor or what.internet info for the loss
Old 08-28-2006, 08:08 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
well i think yo ucan use the pm6 or the pm7. those shoudl work with obd0 mpfi set ups. did you check all the basics. cap and rotor. spark. makign sure the engine sint fludded. ect.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 08-28-2006, 09:12 PM
i currently do not have spark. i replaced the cap and rotor befor i did the swap its weird i know i m getting fuel on all injectors and when i turn the car off from the run position to take the key out i get a large pop or explosion from within the motor so that why i would like to know the wiring all the wires matched up besides the 2 i ran to the dizzy but there are two of the same colored wire and when you alternate them you get an explsion on one setup then you switch them and get nothing im so confused and i am really sick of wiring now and would like to go for a drive
Old 09-03-2006, 11:05 PM
ElbertR ElbertR is offline
Do you get any codes (flashes) on the ECU?
Did you add the 2 extra wires to the Dizzy? I assume you are using a SI Dizzy which is highly recommended.
On the SI, there are two white wires running to the dizzy, don't mix those two up.
When I did my swap didn't get a spark until I replaced the ignition coil in the dizzy (looks like black plastic piece on top inside the dizzy, it is the same part as in a DPFI dizzy).
91 Civic STD HB. Over 280,000 miles on car, estimate about 100,000 miles on engine (D15B1). Original 4-Speed Tranny swapped for DX 5-Speed. Power doors, remote entry, remote hatch popper, power windows. MPFI swap completed!
Old 09-04-2006, 11:18 PM
had the wrong ecu fired up after i got the pm6 runs dam good
Old 09-07-2006, 05:11 PM
DirtyD777's Avatar
DirtyD777 DirtyD777 is offline
Send a message via MSN to DirtyD777
glad you figured it out How's the difference ? noticeable? I was gonna start my mpfi swap in 2 weeks on my next 2 days off, but now I gotta put a clutch in my g/fs crx instead >=/
Old 09-07-2006, 10:04 PM
the diffrence was very noticable feels like a diffrent car im very happy with it but now i want more
