Old 08-28-2006, 06:04 PM
Cruize Cruize is offline
Missing / running rough
I noticed the problem when the brake pedal was hard to press and would not go all the way down. If I kept my foot on the pedal and revved the engine, the pedal would then go all the way down under normal pressure.
Til I get the thing home (less than 2 miles), the brakes were operating normal, but the engine was running really rough.
I can't start the engine unless I press down a little on the gas pedal after I start cranking.
I've already pulled each plug wire from the distributor, one wire at a time, restarted it, and it ran even rougher after each wire was pulled.
I had to move it the other day, so in addition to the new starting procedure, I now need to keep revving it to run almost normal.
The Check Engine light is NOT on.
I thought I should be looking for a vacuum leak. Am I right in my thinking, or should I be testing the TPS, MAF, etc.?
Thanks in advance for any help.
Cruize
1992 Ford Escort GT, 5-speed - Now with an unlimited slip clutch! :sarcasm1:
1995 Blazer LS, 4x4, 4 door
1996 Pontiac Grand Am GT, 5-speed
1997 Suzuki DR650 ~54 mpg
