Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-28-2006, 03:12 PM
mixedgrip mixedgrip is offline
Unhappy Several warning lights (transmission dificulty)
My son drives a 1994 Rodeo that he just recently purchased from an individual. Last week he noticed the batery, and transmission lights along with a couple of others. The transmission then began to exhibit difficulty shifting. The voltmeter indicated just over 8 volts. I charged the battery and took it in for a charge test.
The test showed ~ 13.86 volts with the air, radio and lights on. It also indicated 68 amps under load. After one week with no problem, he called from work and said the voltage just dropped to barely over 12volts but otherwise running OK. I had him turn off the radio, and air. The voltage stayed the same.
He also stated the air was making an odd sound. I haven't heard it yet myself but will tonight. I am planning to take it for an other charge test while it it still running and hopefully before the symptoms disapear.
Any thoughts?
Jim
Old 08-28-2006, 03:20 PM
anthonyn anthonyn is offline
Re: Several warning lights (transmission dificulty)
It's likely a faulty or failing alternator rather than a battery problem. The transmission is going into 'limp mode' because it isn't getting the required voltage. The dash warning lights coming on are another common symptom of a faulty alternator. When replacing the alternator, purchase an OEM or Bosch unit. Most auto parts store units don't last and may be inadequate from the start.
1995.5 Rodeo, AT, 3.2 L, 2WD, 136k miles
Manik Grill guard & Nerf bars, Passport fender flares, Dynomax Turbo muffler, Modified Air intake
Old 08-28-2006, 04:55 PM
Ramblin Fever Ramblin Fever is offline
Agreed, can almost guarantee a faulty or dying alternator; go for the best, which are not cheap, but you will regret it if you don't get a good one from the start. Don't delay this or the transmission will get worse, it's an all electronic transmission and requires the right voltage to shift correctly.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-28-2006, 05:32 PM
surferfletch surferfletch is offline
I'll third the alt. If you search, you'll find a multitude of posts. This is a classic on the Rodeo/Passport board.
Old 09-03-2006, 09:56 PM
Thanks, the second test showed 30 amps with a load and when we took the alternater to get the replacement it bench tested 8 amps. Everything is fine now with the replacement.
I appreciate the help.
Jim
Jim
Old 09-04-2006, 09:32 AM
Curious to know which alternator you used...
