Old 08-28-2006, 02:18 PM
Cloud Strife Cloud Strife is offline
Question o2 sensors
I had to swing by Autozone today to pick up a cap/button for my Blazer and I just remembered o2 sensors.
Now for my truck I believe that there are 4 of them. 2 pre/ 2 after. I have never changed them. I repeat never changed them. When is a good interval to do this and what type of results will occur after the change?
Currently I have new wires, plugs, exhaust, cold air intake, and soon to be cap/button.
I know that they control how the engine tunes the fuel mixture ( unless I am wrong).
Is ths one of the most neglected items?
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
Old 08-28-2006, 02:27 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: o2 sensors
How many miles on them?
Any major problems which might have worn them out prematurely?
tuneups kept up to date over its life?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-28-2006, 02:36 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: o2 sensors
The recommended interval is 100,000 miles, however, the range that they are effective is pretty big. Some people experience problems with them sooner and notice a big improvement in performance when changing them, and some people can go far longer. I've seen them go almost twice the recommended interval with little to no problems.
The results you get depend on how bad the old O2 sensors were.You may not notice any difference, or the differences could be huge.
Old 08-28-2006, 02:58 PM
Re: o2 sensors
Well my Blazer has 131k miles on it.
I just really couldn't tell what the failing o2 sensor symptoms would be.
What interval has everyone changed theirs at?
There have been no issues with the engine. Tuneups have been up to date except for the cap/button. I am long overdue for that. Regular oil changes, new radiator and engine flush. etc etc.
The front end and o2 sensors are what I need to get working on, but if I don't have to replace the sensors yet then I won't.
Optima Redtop
Old 08-28-2006, 03:13 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: o2 sensors
some symptoms of bad o2 sensor(s) would be bad gas mileage, engine missing (PO300 for example), excessive gas smell. these are similar symptoms of a bad fuel injection spider and a clogged egr.
is your truck running bad right now?
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 08-28-2006, 03:33 PM
Re: o2 sensors
I will have to get back to you on this after the cap/button change. If it still runs bad then yes I am having issues.
Optima Redtop
Old 08-28-2006, 08:41 PM
BlazerLT's Avatar
AF -Advisor
Re: o2 sensors
cap and rotor will make a diference.
Old 09-04-2006, 07:01 PM
Jesecourt Jesecourt is offline
Re: o2 sensors
Will O2 sensor make fuel injectors go bad also? I'm also still having o2 sensor problems. Bad gas smell, horrible skipping, flashing service engine light. Any ideas?
Selena
Old 09-04-2006, 07:23 PM
billibong's Avatar
billibong billibong is offline
Re: o2 sensors
Selena - What year is your Blazer? And, what have you done to it - tune up, etc?
Knowing the year and history will help us to help you.
billibong
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 09-04-2006, 07:31 PM
Re: o2 sensors
It's a 96 4x4. We've put new plugs, plug wires, coil, distributor cap & rotor button, 2 injectors. Just about everything known that would cause this thing to skip. Now, they are telling me that the o2 sensor has probably caused the NEW injector (put on yesterday) to go bad. If you need any more info, I'll be online.
Thanks for the quick response!
Selena
Old 09-05-2006, 11:24 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: o2 sensors
Actually 02 sensor replacement is usually more over done.
Even with a 02 sensor code many other things cause it.
To test them you need a good engine capable scanner or lab scope.
They can or may go bad but I have saw many still working good at over 200K
Give it the old good tune up and see what it does.
MT
MT
Old 09-06-2006, 02:05 PM
Re: o2 sensors
Well I put 5 of the six spark plugs in. I will put the PITA plug in next week when I do the Throttle plate mod.
But my gosh those Autolite Platinums looked like crap after only 9 months. Lots of carbon buildup even after a dose of SeaFoam.
I will have to agree with everyone that AC Delco spark plugs are worth their money. I am going out for a test drive this evening to go buy my Dremel for the throttle mod. I will get a good mix of High-way and city so that will tell me if its that last spark plug or I possibly need to replace all my o2 sensors.
Optima Redtop
Old 09-07-2006, 01:47 PM
clubplug clubplug is offline
Banned
Re: o2 sensors
HI Cloud
According to NGK, you can use the following:
1999 CHEVROLET BLAZER TRAILBLAZER / V6 / 4.3
SPARK PLUGS
Spark PlugPart No.Stock No.Plug GapNote
G-Power Platinum TR55GP 3403 0.060
Laser PZTR5A-15 7862 0.060
Iridium IX TR55IX 7164 0.060
WIRE SETS
NotePart No.Stock No.
RC-GMX079 51081
OXYGEN SENSORS
Pre-Cat Left 21006
Pre-Cat Right 21006
Post-Cat Left 21006
Post-Cat Right 21006
Old 09-07-2006, 05:55 PM
BlazerLT's Avatar
AF -Advisor
Re: o2 sensors
AC Delco plugs are better in our engines.
