Old 08-28-2006, 01:34 PM
mpruitt1 mpruitt1 is offline
Exclamation How big do I go?
I have a 2001 Chevy blazer LT4x4. I need new tires and am currently looking at some all terrains. I want to get the biggest size that will fit without rubbing or hurting my gas milage. I know I can fit 235 75 r15. I do not have any kind of lift, it is all stock. Right now I am looking at The BFG all Terrains. any ideas or suggestions? thanks
Old 08-28-2006, 02:29 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: How big do I go?
Any bigger and you will be decreasing your economy.
There is no size range which has the same economy. You increase the size, you add rolling resistance and hence, reduce economy.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-28-2006, 02:43 PM
blazee's Avatar
blazee blazee is offline
Problem?
265/70 is a little bigger than 235/75, and fill the wheel wells nicely. I've ran both. I'm currently using 235/75, because I got the set for $100 cheaper than a set of 265/70, and they're only 3/4" shorter. I get the same fuel economy with both.
Old 08-28-2006, 04:05 PM
redwheeler's Avatar
redwheeler redwheeler is offline
30x9.5 15 fit w/out rubbing its what i have
and yes i am a ASE Master Auto Technician
1996 chevrolet silverado 5.7L 4x4
nothin but a k&n for now i just got it
Old 08-29-2006, 07:28 AM
How are the 30X9.5 r 15 on the gas milage?
Old 08-29-2006, 09:00 AM
BlazerLT's Avatar
AF -Advisor
You are not getting it, anything bigger than stock and you will be decresing your mileage.
Old 08-29-2006, 10:35 AM
Blazrer01 Blazrer01 is offline
Question Re: How big do I go?
I would still like to know what sort of MPG to expect running 30x9.5x15 or 235/75/15.....your'e only looking at a 5-8% difference in circumference and depending on size increase, assuming that the speedo is not re-calibrated - add 5-8% to the miles to calc MPG.
Old 08-30-2006, 04:43 PM
redwheeler's Avatar
on the same routes avraged out it was like 1-2 mpg and they look better fill out the wheel well better
Old 09-03-2006, 05:40 PM
BlazerLT's Avatar
AF -Advisor
You multiply your mileage on your odometer by 1.039 = miles with the new tires.
Old 09-05-2006, 09:45 PM
redwheeler's Avatar
or you just reflash the pcm and poof problem solved
