Old 08-28-2006, 01:22 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
looking to get a 1990 honda accord and have ?
looked at a 90 honda accord with 120000 miles on it very little rust arouund the rear quarters and super clean inside also has power every thing
for only 1500
now my question is other than the basics what should i watch for
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 08-28-2006, 02:01 PM
mpumas mpumas is offline
Re: looking to get a 1990 honda accord and have ?
Did the timing belt, water pump and other belts get changed at 90K? Does the A/C and associated fan work? Any rust in the trunk / area around the tail lights leak water? Oil leaks around transmission, oil pan, timing belt cover, valve cover gaskets? Good engine compression? Transmission fluid not black, smell burnt?
Old 08-28-2006, 06:04 PM
Igovert500's Avatar
blue + red light magnet
Burning oil from bad piston rings or valve seals. Any smoke for that matter. Make sure you don't have a flashing D4 or 'S' light associated with bad TCU or bad speed sensor (make sure cruise works). Motor mounts usually become an issue in the long run. Check for water damage in the trunk, as the tail light seals wear away/get loose and leak. That's all I can think of off the top of my head.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-29-2006, 03:34 PM
havent driven the car yet but thanks for the info
Old 08-31-2006, 08:46 AM
chubbygoatboy chubbygoatboy is offline
If you don't buy it, please let me know where it is at!!
Old 09-01-2006, 07:09 PM
kustom_Ace's Avatar
kustom_Ace kustom_Ace is offline
You mentioned it has power everything. Make sure all of it works thoroughly b4 buying it. From personal experience, any electrical problems in a car can be a real pain in the a** to fix. I just dont want anyone else going through what I did.
Cheers
Always try to DIY. Remember, amateurs built the Ark, professionals built the Titanic.
