Old 08-28-2006, 12:01 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
ATT 91-94 cavalier owners..lil tech help
ok so my pops owns a 92 cavalier and his tensioner assembly took uh shit and lost the belt driving home..now installing the assembly looks easy but im curious if any of u guys know how to remove the power steering pump? and if any of u have already replaced the tensioner assembly..if u could give me any tips and let me know how much of a pain in the ass it will be to do so all input will be greatly appreciated
Old 08-28-2006, 01:06 PM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
Re: ATT 91-94 cavalier owners..lil tech help
What engine does it have?? 2.2, 2.8, 3.1???
Old 08-28-2006, 01:10 PM
my99cavy's Avatar
Well here is how to remove the water pump on the 2.8L and 3.1L engines..
  1. Disconnect battery negative cable.
  2. Properly drain and recover the cooling system into an approved container.
  3. Disconnect the serpentine belt at the water pump pulley.
  4. On 1985-86 models, if equipped with A/C, disconnect the wires at the air conditioning pressure cycling switch and remove the cycling switch.
  5. Unfasten the water pump pulley retaining bolts, then remove the pulley.
  6. Unfasten the pump attaching bolts, then remove the water pump.
Fig. 4: Water (coolant) pump mounting - 2.8L and 3.1L engines
Old 08-28-2006, 01:18 PM
sorry my99cavy..im intrested in removing the power steering pump..and its the 4cyl even a 2.2 or 2.5 hell it might even be a 2.0..in those yrs they only made 2.5 and 3.1 right?> thought they dropped the 2.8..neways i do appreciate the reply..can u maybe steer me in the direction that u seem to be getting this info..thanks man
Old 08-28-2006, 01:41 PM
Young Chuck D's Avatar
Young Chuck D Young Chuck D is offline
Send a message via AIM to Young Chuck D
91-94 is gonna be 2.8, 3.1, or 2.0
1999 Chevrolet Monte Carlo LS [semi-daily driver until LIM repair or trade-in for '13 Fusion, 110k miles]
Gone but not forgotten:
1995 Pontiac Grand Prix GTP[sold, 128k miles]
1996 Oldsmobile Cutlass Supreme SL Coupe [a minivan tore my door off, totaled, 84k miles]
1998 BMW M3 Hardtop Convertible [a pathfinder armada stopped in front of me, totaled, 70k miles]
1989 Chevrolet Cavalier Coupe [died, 160k miles, engine problems]
1990 Hyundai Excel GL [died, 220k miles, died]
Old 08-28-2006, 01:50 PM
my99cavy's Avatar
ahh shit man sorry I didnt read it correctly obviously lol I really dont thing there is such an engine as a 2.5 (at least for the cavy there isnt) but here ya go buddy with the power steering pump theres a diagram for a different couple engines so just find the right one for you. hopefully this helps.
  1. Disconnect the negative battery cable.
  2. Detach the vent hole at the carburetor if so equipped.
  3. Loosen the adjusting bolt and pivot bolt on the pump or release tension on drive belt tensioner assembly, then remove the pump's drive belt.
  4. Unfasten the pump-to-bracket or mounting bolts (through the access hole in the pulley as necessary) and remove the adjusting bolt if so equipped.
  5. Remove the high pressure fitting from the pump.
  6. Disconnect the reservoir-to-pump hose from the pump.
  7. Remove the power steering pump from the vehicle. If installing a new pump, transfer the pulley to the new pump.
  8. Installation is in the reverse order of removal. Adjust the belt tension and bleed the system, as outlined in this section.
Fig. 1: Power steering fluid line routing - 1.8L and 2.0L engines
Fig. 2: View of the power steering pump mounting - 1.8L and 2.0L engines
Fig. 3: Power steering pump mounting - 2.2L engine shown
Fig. 4: Power steering pump removal and installation - 3.1L engine
SYSTEM BLEEDING
  1. Raise the front of the vehicle and support safely. This will minimize steering effort. Fill the power steering pump reservoir with the appropriate type of power steering fluid.
  2. With the engine off, keep the reservoir full as an assistant turns the steering wheel from lock-to-lock several times. Stop with the steering system at one lock.
  3. Start the engine and allow it to idle. Turn the wheel from lock-to-lock several times. Note the amount of air bubbles in the fluid. Repeat the procedure until no more air bubbles appear.
