struts
I have had my Altima for 10+ years and have yet to change the struts. My question is: should I change the struts? Also, what else should I replace? I want my car to have that tight ride it had when I first bought it. Not sure if this is possible. Any suggestions are appreciated.
Thanks, Eddie |
Re: struts
To start off with are the struts done? Push down a few times on the bumper, if it doesn't bounce up more then twice then they are still fine.
I'd look into an upper strut mount brace(better cornering), maybe a set of adjustable coil overs.(adjustable height = lower stance & center of gravity = better handling) Both these items can be gotten for under 100 a piece. If you are going to replace your struts, it depends on if you want a hard stiff ride or just a well balanced handling car, the struts rebound rate will determine which of these u'll get so you might want to consider that. I'd try the 2 items I mentioned above for improved handling, the coils wear over time the same as shocks & struts. Not sure on ur year, but Check these links out: http://cgi.ebay.ca/Bomz-1993-2001-Ni...QQcmdZViewItem They will work with factor struts. http://cgi.ebay.ca/93-97-94-95-96-NI...QQcmdZViewItem Will tighten steering and handling in the front end. If you where to buy anything from these sellers PLEASE use a pay pal account. As sometimes sellers try to screw you over and pay pal allows you to start a claim against the seller and will get your $$$$ back. PM me with any ?'s |
Re: struts
Thanks for the reply. It's appreciated. I will check out the struts and the other items mentioned. Have a good evening.
Eddie |
