Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 08-28-2006, 09:26 AM
Snake007eye Snake007eye is offline
problem installing head unit on my civic 01
Im trying to Install a aftermarket head unit in my Honda civic 01 and the thing is that i dont know how to take out the stock stereo. and in order for me to that i think i have to remove the dash BUT i dont kno how remove the dash... SO if someone knows how to remove it or maybe knows a web site that explains how to remove it would be greatly apperciated if someone can give that info. Thanks
Old 08-28-2006, 10:11 AM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Re: problem installing head unit on my civic 01
You have to push from the back of the unit to pop out a few pins. You dont need to remove the dash just the front console on the 03's and up we had to remove the lower console by the gear box as well..Be mindful of the cig lighter this can cause issues as well.
03.IS300.MT.LSD. 'Supra in Training'
Old 08-28-2006, 10:21 AM
ok so alll i have to do is take out that black piece where da AC switches are?
Old 08-28-2006, 10:28 AM
BrodyP's Avatar
AF -Advisor
That whole piece should pop out here is DIY I found if this helps....
Remove shift boot from knob, unscrew. If it's an AT model, I think the trim ring comes up and then everything else is the same.
Pull up on shift boot. Pull HARD. There are about 6 clips that will come up. The entire center piece will come off.
Remove two screws from the U-shaped piece of trim. They are on either side, about 2/3 of the way to the dash.
Remove 6 clips from the side of the trim. You will see these. You can use a SMALL (read: SMALL!) hammer to knock them out softly.
Pull TOWARDS THE CENTER OF THE CAR (NOT the sides) on the rest of the piece. It should come off with relatively little effort.
Remove 2 screws from the underside, as with the 2001/2002 models.
Remove the dash the same as the 2001/2002 models.
Old 08-28-2006, 10:31 AM
ok i will try it. I'll let u kno what happens. thanks
