Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-28-2006, 02:05 AM
taz600 taz600 is offline
help plz
hey everyone! im new to this scene and could use a couple answers to some ?'s i have. first off i need an opinion on a possible purchase, i might buy a 94 caprice 5.7 but i need to know if this is worth it. it has 157,000 miles and a month old transmission. it also has an issue with the speedo dissapearing and coming back and the headlights sometime wont work.. a friend of mine is willing to let me take it off her hands for $2200 is that reasonable? also to get those problems fixed wat im i looking at cost, part, and time wise? thanks in advance for all help
Old 08-28-2006, 11:40 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: help plz
thats actually an alright deal, what the body and interior like
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 08-28-2006, 12:03 PM
Re: help plz
the body looks pretty good the passanger side door has a small dent and the interior is not bad at all. will the repairs it needs cost me a whole lot and wat could the problem be?
Old 08-28-2006, 01:21 PM
capriceowns capriceowns is offline
Re: help plz
That problem could be free to fix, like a loose ground or a cut/severed wire.
i'd say talk them down to 2,000$ and itll be a hell of a deal.
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
Old 08-28-2006, 01:59 PM
Re: help plz
i dont think i can talk her down to that she wanted 2500 originally, looks like i will just get it and see about fixing the problems
Old 08-29-2006, 06:12 PM
HLandin's Avatar
HLandin HLandin is offline
Re: help plz
The speedo disappearing has been discussed in detail in previous posts. This is usually a sign of corrosion or dirty contact between the instrument cluster pins and its connectors. Clean them and the problem should disappear.
As far as headlights not working, it could be any number of things, but some more information would be helpful. Do they not come on when you switch them on? Do they go out when you switch between your regular lights and your bright lights (dimmer switch)? It could be something as simple as a bad on/off switch, or somehting else. More information will help.
I would definitely suggest doing some research on CarFax.com or some other source, especially since you mentioned a dent in a door. Just like any other car, minor cosmedic imperfections could indicated hidden problems. If it has a dent, it might have been in an accident. If has been in an accident, then it might have damage to the door or even frame that you cannot see. A little research might save you a lot of money in the long run.
The price seems seems good if it has not been involved in any accidents and has a good body. Look any for rust! Since these cars have a lot of metal in the body, a little rust can cause a lot of rust later on if not spotted and treated early. If you don't, you might find your "little problem" has become a REALLY BIG PROBLEM. Once again, a little care now could save you a lot later.
Old 08-29-2006, 06:49 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: help plz
FWIW, when the dimmer switch on my car failed (twice, both times) the headlights would not come on at all. Something to look for.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-29-2006, 08:13 PM
Re: help plz
a good spot to lookl for rust is under the door its self, you have to open it then look at the bottom, they usually rot out.
