Go Back   Automotive Forums Car Chat > Dodge > SRT4
Old 08-28-2006, 01:46 AM
ccopriviza ccopriviza is offline
Send a message via AIM to ccopriviza
where to go now?
I just bought my srt4 a couple weeks ago with an intake, agp 50trim, agp intercooler, hks blowoff, external wastegate, catch can, down pipe, borla exhaust, upgraded motor mounts, turbo timer, and boost controller. What should i do next???
Old 08-28-2006, 12:06 PM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Re: where to go now?
Take it to the track see how it performs.
03.IS300.MT.LSD. 'Supra in Training'
Old 08-28-2006, 11:04 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Return line, bigger injectors, management(safc, emangage, dtec), gauges(30 psi boost gauge, wideband, knock gauge, etc.), intercooler sprayer, ported stuff(intake manifold, head, etc.), cosmetic stuff(rims, cf accessories, etc.) slicks, upgraded axles, a new clutch, new hard pipes, larger throttle body, cams
Point being, the list can go on for days....it's all about what you want. Personally, I wouldn't buy a car that already has mods because it puts you at this point of "what now," but that's just me.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 08-29-2006, 01:38 AM
well i know where i plan to go with the outside but what will help the car perform best from the point im at now.... i heard a new fuel pump, fuel rails, and injectors will help alot any sujestions?
Old 08-29-2006, 03:17 PM
Turbodog97's Avatar
Just a Neon
I would get 7XX injectors, s3 or 255lph fuel pump, a return line with bottleneck fix, and then some sort of management for it all. I'm pretty sure with anything above 650 you can't use an safc and will have to use something like an emanage or ems or dtec.
05 Srt4
97 Mx-5
Old 08-30-2006, 01:41 AM
TEXSRT4 TEXSRT4 is offline
750 injectors, aem ems, set of crower cams, a real exhaust system, and a good tune and your looking at a solid 450hp on pump gas
or a good set coilovers (tein, mopar, or KW - which is the way to go ideally) or hotchkis springs, a set of hotchkis swaybars (GET THEM NOW!!!!!), a set of strut bars, and a set of traction bars, and enjoy a good powered, all around well setup car to drive around in
