Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 08-24-2001, 01:22 PM
kenchan's Avatar
kenchan kenchan is offline
Thumbs up no sulfer smell, better milage?!
just following up to say that it's been over a week from the day i got the sulfer smell TSB taken care and there hasn't been one sign of that stinkin' smell. on top of that, I also noticed that I am now getting a hell of a lot better milage per gallon... could this be related to taking care of this sulfer smell???
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 08-24-2001, 09:42 PM
91g20 91g20 is offline
sulfer smell??
What did the smell turn out to be?
Old 08-25-2001, 06:39 AM
primera man's Avatar
"P-Man"
I hope the problems are gone to....you've had a bad run lately with your G20
View All My Models Here.
Old 08-25-2001, 10:37 AM
kenchan's Avatar
oh, that was the TSB for reprogramming the ECM. something with the wrong parameters while ideling. it totally stunk up the whole midwest when it was ideling....embarrassaing as hell as you know having a brand new car stinking up the place.
yah, if the instrument pannel buzzing noise inside can be fixed, I would consider this a very happy buy. it seems that the cables going to the guages are buzzing against the cluster. what is weird is that when the engine is warn, there's no noise. its that first 15min that sucks. on top of that, I have the aftermarket muffer that makes more vibration so it aint helping. hehehee
score card is about 85% for this car right now. it'll jump to 95% if I can get that noise fixed. 100% after I get a NOS kit. eeeheheheh.
Old 08-28-2001, 12:47 AM
T4 Primera T4 Primera is offline
The reason it only does it when cold is most likely the engine rpm is a little higher until ECU sees temperature increase. That certain rpm will set up a sympathetic vibration in whatever is making the buzzing sound.
Take a note of the cold start idle rpm and, then later when hot, throttle it up to that rpm and the buzzing will likely return. My P10 has a buzz from the windscreen washer filler cap touching the fender at exactly the same times (cold idle of around 1200rpm or when passing thru 1200rpm.) Another place where buzzing can come from is the wheel well inner guards buzzing against the fender.
Old 08-28-2001, 03:47 AM
pearl-p10 pearl-p10 is offline
Thats funny,
my p-10's washer cap used to do that too. All I did was put a piece of tape against the side of the fender where it was touching. Fixed it right up.
Kevin
Old 08-28-2001, 10:03 AM
kenchan's Avatar
yep very true. its about the same 1200 where my p11 vibrates when its cold too. wish i could fix that! I might put on a attractive clamp over the top of the cluster to put on a guage or my passport 7500 on there.
it seems like there are 2 areas of vibration. tip of the cluster and inside somewhere in the instrument panel.
Sulfer Smell grandamlv Camry/Camry Hybrid/Vista 3 03-15-2008 03:02 AM
Getting a sulfer smell at start up. alotech Crown Victoria 1 09-22-2006 01:38 PM
sulfer smell 97 V6 rustyrun 4Runner/GX470 7 07-08-2005 10:41 PM
Cologne Poll:What smells better, hollister Drift or abercrombie Fierce? HondaCivic4358 COMPLETELY off-topic 18 05-29-2005 04:20 PM
sulfer smell mud 4Runner/GX470 0 01-13-2004 06:38 PM
