Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-27-2006, 09:02 PM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
in line fuel filter???
Hello,
Driving my 1996 mitsu. spyder gs eclipse has gotten a bit different.
While accelerating in every gear excluding 1st and reverse between 1-3 rpms my car seems to cut on and off making a jerking kind of motion
I was told this is a common symptom of the in line fuel filter and or fuel filter on the in-tank fuel pump...
Where are these filters located on the vehicle? How do I replace them?
T R U E E C L I P S E
1996 MITSU. SPYDER ECLIPSE
[email protected]
http://www.cardomain.com/ride/653950
Old 08-27-2006, 09:33 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Re: in line fuel filter???
the in-line fuel filter is
A under the hood
b right in front of the passenger side wheel
the fuel pump is under your back seat
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 08-27-2006, 10:24 PM
nova1313's Avatar
nova1313 nova1313 is offline
in the spyder gs it's under the hood down below the battery tray mounted on the firewall. Remove the battery and tray for semi easy access. That is a common symptom and it's a cheap fix if thats the problem.
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 08-27-2006, 10:45 PM
xavier3jr's Avatar
it is either or i've got a 95 gs and a 96 gs on the 95 its under the hood on the 96 its in front of the rear passenger wheel
Old 08-27-2006, 11:42 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Spyders might be different? Not sure...but I think 96+ it was in the rear by the passenger tire.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-28-2006, 02:04 AM
okay I will check in those places, what if it is the In fuel tank filter... Thats probably a harder filter to replace...
What does the in line fuel filter look like and what types of shops would repair something like this...
how easy is it to do my self, any suggestions or sites or has anyone done it?
[email protected]
