Go Back   Automotive Forums Car Chat > Cars in General > Exterior | Bodykits | Lighting | Aerodynamics
Exterior | Bodykits | Lighting | Aerodynamics Discuss different body kits, body work in general, and all types of exterior modifications.
Old 08-27-2006, 09:58 PM
austinnp austinnp is offline
Best way to clean this up
I am trying to figure out the best way to go about cleaning this up before it becomes a bigger problem, on that back tire holder I figure I could sand it down real good and just prime/paint it again, on the bumper I gotta do what? Chip it outta there then try sanding it down and fill it in with bondo if I have too?
Looks are not of great importance, just getting rid of the rust and getting it a shade of black is all I am looking for.
Just looking for some guidelines here and perhaps what kind of products, ie what kind of sandpaper or should I pickup a piece of hardware?
Anything would be apreciated, thanks
Old 08-28-2006, 09:10 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Re: Best way to clean this up
Best thing to do is get a good quality hand held grinder with grinding wheel and use it to grind the rust off but make sure you go past the rust under where the paint still looks good to make sure there's no rust under it too. As for the rear tire holder use the grinder on it to and that will also help knock down the large welds on it and make it appear to have been built better at the same time. If you do it that way use the grinder to get rid of the rust use around a 2 or 300 grit sand paper then get a red scrub pad which is the same as about 600 grit and after all that it basically takes it back to looking like satin polished steel then prime it good and paint it good.
Old 08-28-2006, 09:15 PM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
Well the obvious cure to rid that problem is to replace them with new parts or new-used parts.
