Old 08-27-2006, 08:40 PM
Schrade Schrade is offline
upper pin without help?
I got the lower pin changed without help, since there's play in the upper pin/bushing. Took an hour.
Now, can I do the top without pulling the spring, and without putting stress on the lower new pin/bushing?
Old 08-27-2006, 08:43 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: upper pin without help?
check the FAQ, it is already covered.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-27-2006, 08:52 PM
Thanks!
I did a search for 'upper pin without help'. Results:
http://www.automotiveforums.com/vbul...l&titlesonly=0
I saw the procedure thread for both pins, with buddy.
Nooooooowwwwwwwww..., where were we???
EDIT:
Just found another link for the pin/bushing change. It also said get help.
I've done the bottom.
I need only to know from anybody who's done lower and upper by himself...
Thanks!
Old 08-28-2006, 05:48 PM
Cruize Cruize is offline
Quote from reply in FAQ: Replacing door hinge pins and bushings illustrated:
I did remove the door myself, but I would recommend a second set of hands. I had the window fully opened so I could grab the frame. I put a floor jack and some wood beneath the end of the door to realign it (really bad bushings and an egg shaped hole in the hinge) and also to hold it in place.
I'm sure you could use cargo straps to secure the door to an overhead support and hold it in place.
I don't know if you can drive the pin out without removing the spring.
Cruize
1992 Ford Escort GT, 5-speed - Now with an unlimited slip clutch! :sarcasm1:
1995 Blazer LS, 4x4, 4 door
1996 Pontiac Grand Am GT, 5-speed
1997 Suzuki DR650 ~54 mpg
Old 08-28-2006, 06:23 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
The spring has to come out..I just did two Friday...
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-28-2006, 09:23 PM
frankjc frankjc is offline
I found a chair that was the perfect height to support the door when I removed it from the vehicle. Took me about 20 minutes to to the last one. I still don't have the spring back in yet though.
Old 08-28-2006, 09:41 PM
I used a clamshell type compressor I got with a chevy valvetrain kit... It was narrow enough to get right in there..
Old 08-29-2006, 04:53 AM
muddog321 muddog321 is offline
AF -Advisor
Auto body and paint stores all sell the spring remover/installer for around $15 and while you can pull it out without one (watch it fly!) its nearly impossible to put it back in without and you may get hurt. Upper and lower bushing should be done with the door separated (pins out on both) then line up and insert the pins.
