| Latest | 0 Rplys |
| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Show Printable Version | Email this Page |
#1 | |
![]() Join Date: Dec 2005
Overheating PLEASE HELP!!!
I've got a 1991 Mustang Gt 5.0 it has a F/I 306 fully fordged and balanced w/ Twisted wedge heads, Trick flow headers, cobra intake, 25 lbs. injectors, a E303 cam, High flow water pump and a Griffen 3 core radiator, and a eletric fan.
Every time I take it out no matter how I drive it, it gets hot on me and overheat's What do I need to do? PLEASE HELP! |
#2 | |
![]() Join Date: Feb 2006
Re: Overheating PLEASE HELP!!!
Check Radiator Fluid
Water Pump Bearings Thermostat Carry it to a mechanic. |
#3 | |
I usually use this time to reflect back and then always replace the Thermostat when i come across this problem
#4 | |
![]() Join Date: Aug 2006
Question-- are you seeing any mist coming out of your vents when you turn on the air?
#5 | |
have you bled the coolant for air pockets?
have you done a compression test for possible blown headgasket? checked the plugs? If a plug looks rusted that's a sign of coolant getting into the cylinders, blown headgasket. how much CFM does the electric fan blow, and how do you have it setup to run? Is it running constantly, or is it cycling on/off allowing the car to overheat? |
