Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-27-2006, 05:00 PM
ralpht44 ralpht44 is offline
1994 Passport engine miss
I have a 19994 with a 3.2 V6. Engine has a miss in lower gears mostly in first and second. When I get her up on the highway she runs great. I had a mechanic recently tell me he suspected it was a valve but I thought if it were a valve it would be consistent all the time. Any insight would be appreciated.
Old 08-27-2006, 05:10 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 1994 Passport engine miss
When was tha last time you replaced the fuel filter?
ever had the injectors cleaned?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-27-2006, 07:27 PM
I haven't done anything as of yet to it. I am not sure of the history as I bought it at an auction.
Old 08-27-2006, 09:47 PM
Cat Fuzz Cat Fuzz is offline
Pop the hood in the dark with engine running and see if there is any arcing from the spark plug wires.
Old 08-28-2006, 06:33 AM
redbug redbug is offline
I had a miss on my 95 rodeo, it was constant... Turned out to be an injector. You may want to do a compression check. Or, do the poor mans compression test. Remove the spark plug wires from the coil and turn the engine over, if you hear a wah, wah, wah, wah, wha, wha, constant noise from the starter you probably have good compression. If you hear wah, wah, wuh, wah, wah, wah, wah, wah, wuh, you may have a bad valve.....
Old 08-28-2006, 09:31 AM
Also seems to lose power at times. I do have a slight tick in the lower gears. I have been doing some research and everything seems to be pointing to the timing belt tensioner which is infamous apparently. I have 106k on the engine so it may be due.
