Go Back   Automotive Forums Car Chat > MG > MGB
Old 08-27-2006, 08:27 AM
tombubrick tombubrick is offline
right rear sits lower,why
Have had my vehicle with my daugher for two years now, just took it back as she is off to college. The visible clearance between the tire and the wheel well is two inches less on the right rear side than the left.
Any quick thoughts?
Thank you.
Old 08-27-2006, 09:26 AM
Knap Knap is offline
Re: right rear sits lower,why
http://www.mgb-stuff.org.uk/
Under spanners should be a section on ride height (sorry can't direct link) measure all round and compare as plenty of variation.
Old 08-27-2006, 12:24 PM
Was thinking that perhaps a spring or shock absorber might be worn out.
Old 08-27-2006, 04:16 PM
Flash75 Flash75 is offline
AF - Advisor
Shock Absorbers don't affect the ride height. Look for a weak or broken spring or spring mounting hardware. Measure the ride height from the bottom of the chrome strip to the center of the wheel cap on all four wheels to see which rear wheel is wrong. The height in theory should be equal on all four corners but in reality it may vary as much as an inch.
Clifton
Old 08-31-2006, 01:28 PM
KimMG KimMG is offline
AF - Advisor
It's common for the driver's side spring to wear more than the passenger side since most of the time the car is only loaded on that side.
