Old 08-25-2002, 02:33 AM
BullShifter's Avatar
MSD Ignition updrade
I will be installing a upgraded ignition system tomorrow. I was planning on doing today but i'm gonna have to get some metal from the hardware store to make custom brackets for the control box. There is no place to mount it under the hood so i'm mounting it behind the gtove box. For the coil, that is already mounted under the intake piping. This sytem has a rev limiter:alien: Which is a very good thing.
Anybody else intall an after-market ignition system?
Where did you mount your box?
Any improvements?
Old 08-25-2002, 03:42 AM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
i to am installing my msd ignition tomorrow (actauly today) i go thte MSD SCI, coil, and cap.... i mounted the the ignition next to the MAP sensor behind the intake manny.... im having trouble mounting the coil somewhere... you have a pic of yours so i can get an idea?
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 08-25-2002, 03:56 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I'm planning on an MSD ignition (sorry Eric, haven't had a chance to send you that money order yet), and I figured out where I'm going to mount it.
I'm relocating my battery to the hatch area, and I'm going to mount it to the old battery tray.
Old 08-25-2002, 05:45 PM
i mounted the coil under the intake piping & the right fender well
now for some reason my car dont want to start
i'm taking a :bonghitte break cause i'm starting to get mad
Red- battery +
Black - ground -
Orange - coil +
(2)black- coil -
(2) red - old coil +
White - old coil -
I mounted my SCI box in the car to keep it cool
removed the glove box(2 10mm bolts)
fab a bracket & its mounted on the ventalation ducting - pretty trick
& is very to change the rev limiter chip
but there is only 1 problem - not running at this minute
i will return the garage to probe the wires to see whats up it
starting to get on my nerves
update sometime later
Old 08-25-2002, 07:59 PM
okay i got mine installed. the car fired right up the first time... but now my tach is acting funny.... doesnt work until i touch it.....hmmm o well i have a tach on my Super-AFC.... so until i can get more time to look at things i'll just have to use that one. I'll post pics as soon as i can get some... (its raining here hard now)
Old 08-25-2002, 11:27 PM
I got mine running. It was just a bad connection
The control box is a little noisy, that's what I get for mounting it inside the car. After 3,000RPM's the engine is louder than the Ignition. Or I can just raise the volume on the radio if it gets annoying
MPG of 93 Dakota 5.2 Magnum w/MSD Ignition tripod12133 Dakota 0 07-27-2010 11:21 PM
FOR SALE: MSD Ignition APEXSER Classifieds 1 01-14-2002 09:19 AM
msd ignition unit with turbo bluecivicdohc Forced Induction 4 01-10-2002 10:23 AM
msd ignition vs stock ignition cas8_1999 Engine 16 01-05-2002 04:31 PM
