Old 08-26-2006, 11:34 PM
Im3good4u's Avatar
Im3good4u Im3good4u is offline
Heater Core???
1-My car has been over heating.
2-I've been getting the coolant syrup smell in my car.
3-My girlfriend was complaining that the her feet were really hot in the passenger seat.(Were the Heater Core is)
So i need help. Does anyone have any clue what is the cause of this.
Can my heater core be bad although i never use it.(Miami)
Could it be the hose that has a leak?
I need help quickly.
Water Pump- Radiator are both less than a year old; and the thermostat well i removed that about a week ago when it first gave signs of heating up?
Any help is appreciated thank you.
1998 Trans Am Bone Stock...For Now!
Sold 2004 Dodge Ram 1500 QC Hemi W/ K&N Air Filter, Superchips Tuner.
Sold 1994 Firebird Formula W/ Hooker Headers, Magnaflow Exhaust, Ram Air, Fuel Pressure Regulator.
Quiters don't win, Winners don't Quit.
Old 08-26-2006, 11:42 PM
Im3good4u's Avatar
Re: Heater Core???
Oh and it would be very helpful if anyone had diagrams or pictures as to were the dam heater hose is.
Old 08-27-2006, 08:53 AM
CamaroRS92 CamaroRS92 is offline
Re: Heater Core???
1)The heater core , good or bad, will have no effect on the car over heating. There are other cooling system issues to be addressed concerning this such as dirty clogged radiator cores, improper water / coolant mix ratio, faulty radiator cap, poor water pump performance, leaves and debris, or bent fins on the radiator or condensor core obstructing air flow thru the radiator and a/c condensor & ect., missing air dam, inoperative cooling fan, bad fan switch or relay............................................. ...........................
2) yes the heater core can leak even if you never use it.
3) hot feet on passenger side could be a stuck or inoperative blend door.
another possibility is a missing heat shield over the Cat Converter or an improperly tuned / timed engine causing excessive Converter and exhaust temps.
Old 08-27-2006, 11:10 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Heater Core???
Sorry but I disagree. The heater core could be the exact reason your overheating. If its clogged (which is very very common) or damaged. The coolant could be leaking out and causing air to get into the system and causing hot spots and not delivering proper cooling to the rest of the engine. I would check the coolant level and replace the heater core ASAP before some damage is done, if its not done already.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-27-2006, 11:35 AM
Im3good4u's Avatar
Re: Heater Core???
Ok i know overheating is usually caused by all the things you said but as i said all my stuff(radiator, water pump) are pretty new.
Does anyone know how i would go about replacing the heater core.
Also the smoke that come out when my car over heats is coming from under the passenger side exhaust. WHAT IS THERE?
Were are the heater hoses?
Old 08-27-2006, 11:38 AM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Heater Core???
The heater core must be taken out from inside the car. You need to detach the hoses from the passenger side rear of the engine bay then take out the glove box and remove the fasteners and pull it out.
Old 08-27-2006, 12:56 PM
Im3good4u's Avatar
Re: Heater Core???
Alright i just took my car to a mechanic and it turns out i blew a headgasket...Thank you guy for your help then only thing you guys could help me with is if anyone knows a good mechanic in miami, fl.
Old 09-05-2006, 09:24 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Heater Core???
This is exactly where I was going to go with this, if there is a head leak, all the gook will gather in the heater core. Make sure they back flush the system.
