Kaboom
When the timing chain goes, what are all the things that can happen? What will happen inside the engine? Some say it'll blow up, others say it will merely turn off. The scenario is when the chain breaks after countless miles of knocking against the valve cover because of a faulty chain guide...
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
Re: Kaboom
kaboom is right....valve damage most likely, and a whole lot of other stuff i dont know about. think of it this way; if you drop a glass cup on the floor, it may not break, but theres a damn good chance it will.
![]() S13 Silvia Q's - R.I.P. R32 GTST Type M Sedan - Sold R32 GTST Type M Coupe - Sold S14 Silvia K's - daily R32 GTS4 - BETTER BE READY!!! |
Re: Kaboom
Re: Kaboom
if my understanding is correct, the crankshaft moves the chain, the chain moves the camshafts, and the camshafts controll the valves. thats where it gets the name "timing" chain, since part of its job is to keep the engine parts synchronized. if the chain were to snap, then you would still have a moving crankshaft and moving camshafts except they wouldnt be connected, so they wouldnt be synchronized, and thats where the problems come into play.
Re: Kaboom
If the timing belt breaks on a non-obstruction engine then it simply turns off and doesn't start until the belt is replaced. If the timing belt breaks on an obstruction engine, the valves hit the pistons and the engine goes in the garbage. Now I would assume that it's the same principle with a timing chain, only thing is that you got that metal chain flying around which can't be all that good.
Re: Kaboom
I'm going away to college. I may have to drive this thing with me if I don't buy a new car. Since I have no time to do this myself, I got a frickin high quote from a garage to do it. I'm screwed.
Re: Kaboom
Still, getting it fixed for a thousand is better than buying a new car I don't want. I think i'm gonna do that.
Re: Kaboom
I've never heard of it breaking tho... I doubt it'll just snap like a timing belt tho
Re: Kaboom
Re: Kaboom
lol, you need to change a timing belt at that milage, a timing chain should last like 250k!!
Re: Kaboom
Re: Kaboom
Does anyone know what bad tensioners do to performance?
Re: Kaboom
Re: Kaboom
Okay so what does bad timing do to performance? The chain is making a lot of noise recently.
Re: Kaboom
You don't need to change the chain, all you gotta do is take out 2 tensioners, there's a really good write-up here....
http://forums.nicoclub.com/zerothread/105618 |
