What a father will do for his daughter...fuel pump change-out..
Or am I one gene away from the three stooges;
This may be long.... The daughter (17) went to a Korn Family Values Concert today(what an oximoron that is), so I decided since she got a ride I'd change out her fuel pump on the '96 Sunfire. (140k miles, original pump,no codes showing,cleaned EGR,MAP,IAC,it stumbles at highway speed, and quits when warm at slow-down to stop) Started at 8:30am, had the tank out by 9:00, pump out, cleaned out the tank,new assembly in by 9:15,new filter on, tank back up by 10:00. Turned the key on,checked for leaks, none, Hooooorayyyyyy. Cleaned up, called the wife out to back the car out of the garage; started the puppy up and massive gas leak by the rear of the tank, must've dropped half a gallon before it got switched off. Jacked it up again, took a peak, and saw that the return line to the tank got crimped. So off to NAPA to by a foot of hose to scavange the broken steel hose. Couldn't find my tube cutter, so off to ACE to buy a new one. 12:00pm, done again. turn key to on, check for leaks; none. Start car up, runs fine, no leaks. Down to the local fuel center for some petro (3.3 gallons for $10.00 on DAD), the freaking gas gauge doesn't work. Up on jack stands again, drop the tank, and the darn gauge connector is disconnected (only has a snap on fitting, the pump connector has a pin to hold the conn. on). button everything up again, no leaks, runs fine, GAUGE DOESN'T WORK. 2:00pm, drop the tank again(#3). Experiment with sending unit in 5 gallon bucket of fuel, the bugger sticks at empty when you slant it backwards. Of course, with the car rear-end on jack stands, it's tilted backwards. Re-assemble again, rap the tank a few times, turn on key, NOTHING. No whirring, no pressure, NOTHING. Drop the tank for the fourth time, I AM AN IDIOT. I forgot to put the pin in the pump connector, an of course it was disconnected. Reconnect, insert pin, my arms feel like lead weights, but I get it back together at 5:00 pm, start it, an everything works. Hit the shower by 6:00, and I'm ready for bed. Boy, do I ache. Just told the 13 yr old son, he has to do all his own work when he starts driving, I'm too old for this.
It's my opinion, don't take it personal. '04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC |
Re: What a father will do for his daughter...fuel pump change-out..
I know exactly how you feel. I have done the same sort of thing for my oldest son. He is a good kid just not too machanically inclined although he is learnging. Of course I would do anything for my family!
just wait, when the son wants a 255LPH pump in his car for some horsepower mod, you'll be there. especially when he takes you for a drive and tells you to try to grab the $100 bill on the dash LOL
My time is coming, two sons, 9 and 7, I'm in so much trouble. Also my daughter, she's a gear head, but she's only 4.
Or when he's driving his 300 HP 289 Powered Ford Mustang! =))))))
BTW the 289 mustangs are a killer combo, nice power and lower weight in a musclecar package
