Old 08-26-2006, 01:56 PM
kjnphx kjnphx is offline
Infinity volume problem
when I turn the volume up, the sound gets quieter and 30 or so seconds later it is blastin anyone else have this problem and how could I fix it.
Old 08-26-2006, 02:39 PM
sLADe781 sLADe781 is offline
Re: Infinity volume problem
LOL That happens to me sometimes too and I have no idea what's wrong with it. I laugh because it's scared my passengers more times than once. Hehe What I usually end up doing is just using the controls on my steering wheel.
Old 08-29-2006, 09:13 PM
nobody else know what the deal is
Old 08-29-2006, 09:22 PM
AutostradaVR4 AutostradaVR4 is offline
sounds F'd up. look for a new head unit bro...or pull the old one and clean/fix it if you know about electronics.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 08-29-2006, 09:28 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Probably has to do with the volume knob, on my old SL it would turn down when I tried to turn it up if I didn't go slowly. New headunit ftw!
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 08-29-2006, 09:33 PM
Yea i know nothing about electronics probably go with a new headunit.
so what is a good headunit i could get thats not too expensive? also my gay ass driver side tweeter broke the other day whats a good tweeter? or will any tweeter be good
Old 08-29-2006, 10:49 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Polk and Infinity both make for nice tweeters. And if you don't mind me asking in what way has your tweeter expressed homosexual tendencies?
Old 08-30-2006, 09:03 AM
^ROFL.
Have fun replacing that tweeter. If i recall, you have to eather pull the whole dash or pull the windshield.
Head units...normally i dont recommend it, but look on ebay. I got my Clarion on ebay 4 years ago for $100 brand new. It STILL sells for more than that today. Awesome deck. Just make sure its New In Box (NIB) and pushes at least 200w (50x4).
Formerly BlinkRA182
Old 08-30-2006, 01:10 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
ummm, the high frequencies it puts out = high pitched voice
na, the tweeters just pop up right out of their holes. quite easy, actually.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-30-2006, 01:25 PM
^ good news, thank man. Mine could use replacing too, but i assumed it was just as hard as replacing the vents.
Formerly BlinkRA182
Old 08-30-2006, 02:13 PM
Linebckr49's Avatar
as for the vents, when i replaced mine, i actually took the entire dash off. needless to say, when i replaced the dash, i had about 10 screws leftover. but i wouldn't do it again. a lot of other people just pop the dash vents in from the top, or glue them in. its not worth removing the dash.
93 3000GT base
Old 08-30-2006, 05:19 PM
because all of a sudden it just cracked or something and when the bass is high most of what you can hear is the little pieces of it popping around.
Old 08-30-2006, 05:26 PM
Linebckr49's Avatar
you won't hear the bass through the tweeter, if that's what you're implying. the tweeter is only meant for high frequencies. however, if the bass is turned up, it will shake the car a bit and can shake the broken pieces of the tweeter.
93 3000GT base
Old 08-30-2006, 05:30 PM
Yea exactly. its just annoying.
knowing me tho i probably wont fix or replace anything anytime soon tho
Old 08-31-2006, 04:27 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
My volume control has gone to hell on the unit. If it weren't for the controls on the steering wheel, I'd actually have to do something about it.
Resistance Is Futile (If < 1ohm)
