Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-26-2006, 02:49 PM
rodeovyn's Avatar
rodeovyn rodeovyn is offline
Question '99 LSE Won't Start
'99, LSE, Rodeo, 3.2L
Ok, my Rodeo ignition just up and died on me. When I turn the key in the ignition absolutely nothing happens. I have a good battery, alternator, new alternator wiring harness. Lights, radio etc. all work. Just put in a new Mouser relay for my intermittent wiper function.
I checked ALL the ignition fuses inside and under the hood. Checked all the wiring connections and everything is tight. Unfortunate for me I put in a brand new starter and NOTHING - it still won't start!
The only other electrical problem I have been having is with the horn, its been sticking inside the steering wheel and I've had to pull the fuse under the hood to turn it off.
I'm totally open for any help troubleshooting this problem!
Old 08-26-2006, 04:23 PM
anthonyn anthonyn is offline
Re: '99 LSE Won't Start
Check the ignition switch. You could jump the starter terminals to see if the starter will turn while bypassing the ignition switch.
1995.5 Rodeo, AT, 3.2 L, 2WD, 136k miles
Manik Grill guard & Nerf bars, Passport fender flares, Dynomax Turbo muffler, Modified Air intake
Old 08-26-2006, 04:40 PM
rodeovyn's Avatar
Red face Re: '99 LSE Won't Start
Thanks for the reply...hmmm, how do you jump the starter terminals?
Old 08-26-2006, 06:55 PM
amigo-2k amigo-2k is offline
Isuzu Guy
did the truck ever start with the new mouser relay in?
My guess is you have a bad starter
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-26-2006, 08:04 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Its quite possible you got a bad starter from the store. I've had that alot from autozone and checkers, a couple times from napa. My boss went through 4 starters from napa before finding a good one once.
They might work fine on the test bench at the store but not in the vehicle. Their test benches put out over 1k cranking amps. I've had that happen before.
Its also possible that the starter isnt mounted exactly right and is binding. I had to redo mine several times before it didnt binde. At the time I didnt know about keeping the dowel pins from the old starter to put in the new one. I ended up having to tighten the bolt closest to the frame first. You can check by loosening the bolts about half way then try, if the starter turns then you were binding.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
