Old 08-26-2006, 02:19 PM
RobFl64 RobFl64 is offline
Unhappy HELP! fuel problem is eating me up
I have replaced fuel pump and main relay. With the line disconnected at the tank, when I turn on the key or crank the engine I only see a trickle of fuel. ECU seems to be working properly and have switched it out with a donor car. Engine does fire if fuel is sprayed into throttle body. What am I missing?!!
Old 08-26-2006, 04:50 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: HELP! fuel problem is eating me up
Remove the fuel pump and inspect. The pump should produce a strong stream of fuel. You don't have fuel pressure to the injectors.
Old 08-26-2006, 07:30 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Put a fuel pressure guage on your fuel filter at the pressure relief, then leave it there (don't take it back out, it will help with tuning your car)
Turn the key on, then check the guage for pressure, or have someone else handy to check for you, after the main relay clicks off, it may drop line pressure back to 0
Your problem sounds like either the Fuel pump, or check valve
Will it stay running after you put the spray to it? or does it just shut back off in a sec?
Old 08-26-2006, 11:48 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Fuel pumps dont gush massive ompunts of fuel, but they shouldn't be trickling. They build pressure though, like they said, put a guage on it.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 08-27-2006, 09:21 PM
Thanks for the replies. Have had this problem for a while. This is the second fuel pump. I think it is electrical. At one point when you turn the key on the fuel pump was rapidly switching on and off. That was last week. This week no fuel pressure. Just saw a guy in the 92-95 forum with a similar problem on a 93 civic.
Old 08-28-2006, 12:21 AM
Time to break out the wiring diagrams, and start testing wires.
Old 08-28-2006, 01:59 AM
FrodoGT's Avatar
Check grounds, and also the relay that controls the pump, if it doesnt get enough power from bad connections then it will kick on and off, but they dotn take much power to begin with.
Current project:
Rio Red 91 hatch.
Old 09-16-2006, 01:34 PM
THANKS for all the help. Found a bad ground. Almost replaced the wiring harness and stumbled on it. Phew. Glad that's done.
Old 09-16-2006, 05:16 PM
FrodoGT's Avatar
Those damn grounds cause so MANY problems...
Current project:
Rio Red 91 hatch.
