Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-26-2006, 12:38 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Head rebuild time
Well the MSD ignition came in today!!!!! ....................still no start
so the only other thing i could think of was bad head gasket warpped some valves.( what led me to think that was because after i did the motor swap its always ran hot)
well guess what i checked compression in the first 2 cylinders and #1 had 50 lbs and #2 had 74.....needless to say i didnt go any further.
so my questions are.....first off im trying to get a loan to just get it all done at once but if not can i do lifers valves retainers all of the goodies and not have to get cams right now.
second question im gana keep this car N/T so i wont to build it for N/T what would be the best way to go build the head as in parts and what all i should get done to it....
please help me out guys because i really have no clue
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 08-26-2006, 01:11 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Re: Head rebuild time
I would probably get it ported if I was you. I am rebuilding my head right now too and I am most likely getting it ported. Parts include valves, springs, retainers, guides, valve locks, new water pump, new thermostat, new gaskets(mani-turbo)(mani-head)(head gasket), and cams. I am getting it ported 1mm over too. It gets pretty expensive in the labor when you port the head though.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 08-26-2006, 01:46 PM
xavier3jr's Avatar
well from what i've heard i wont get much of a gain geting it ported and ploished mabey 10 hp and 600 bucks aint worth 10 hp to me...i would rather make it up somewhere else.
but my main question is if i get a loan it dont matter but if i cant get the loan im not gana be able to buy the cams right now. but i know when you go with bigger cams you gota have diffrent rockers and lifters if i could buy the rocks and lifters i need'd for those cams would they also work with my stock cams untill i can buy the aftermarket ones
Old 08-26-2006, 02:54 PM
NateS's Avatar
That's over my head. I didn't think the rockers and lifters mattered if you got performance cams...I guess they could for the 420a but, I really don't think it maters with the 4g63.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 08-27-2006, 08:24 PM
xavier3jr's Avatar
well looks like im rebuilding the whole motor lol
anywayz im proably gana order everything off of concept illisuions they have very good prices and namebrand shit anways its gana all add up to around 2,700 for EVERYTHING new water pump oil pump pistons rods barrins rings valves retainters guides rockers lifters i mean any and everything you could possibly think of to rebuild your motor. you guys think that is a good price? the only thing that doesnt include is the cams
im thinking about going with crower stage 2 cams
Advertised Duration Intake/Exhaust 240 / 240
Duration @ .050 Intake/Exhaust 192 / 192
Gross Lift w / 1.75 .310 / .355
thats the specs for them and there 486.99 let me know what you guys think
Old 08-27-2006, 09:17 PM
xavier3jr's Avatar
Bottom end
Crower Rods
JE 8:8:1 Pistons .20 over
Melling oil pump
STD rod bearings
STD main bearings
ITM water pump
T belt with bearings
ARP head and main studs
Cosmetic .020 headgasket
Head
Qualfast STD valves
Crower springs with titanium retainers
BLE solid lifters
felpro valve seals
SBI quides
Crower stage III cams
also full gasket set all adds up to a total of
$3,627.87
what do you guys think?
Old 08-28-2006, 12:31 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I think you're going WAYYY overboard for keeping it a NT. You could keep the bottom end stock and be completely fine and probably save half of your total, if not more. What you have listed for parts is what the turbo 420a run 20+psi on all day long. I think your head list looks good though, but with those mods, a port job would do a little more justice than just 10hp, and porting isn't that tough. Just practice on a junk head first and then do a good job on your built head. But for the bottom end I would just go with this:
.20 over stock pistons
Stock rods
Standard Clevite 77 main and rod bearings
Stock oil pump
Waterpump of your choice (Napa has some good waterpumps)
Mitsu Timing belt, tensioner, & idler pulley.
ARP studs
Cometic headgasket
95 Talon TSI AWD
97 Eclipse GST
Old 08-28-2006, 04:41 PM
xavier3jr's Avatar
im not keeping it n/a if i build it lol. that was the original plan but to get the most power and to get the best results im gana have to turbo it.
