Old 08-26-2006, 11:35 AM
egc519mzl egc519mzl is offline
G Voyager Differential Cover
Hi,
Has anyone resealed the differential cover of a 97 G Voyager with 3.3L? Mine is leaking badly. I dropped the pan recently and the pan side is now clean and dry but cover of the thing behind the pan (I think it is a differential cover), it is always wet.
If someone has done it before, I want to know what it takes to reseal it. Do I have to remove the cradle plate? Can it (the cradle plate and differential cover) be removed alone? I mean, no other things to take out before it can be removed?
Thanks
02 Ford Focus @ 306K
97 G Voyager 3.3L V6 @ 122K. Trans leak fixed 5/2007
94 Jeep G Cherokee Laredo 5.2L V8 @ 159K re-fixed transfer case
last update : 01/23/2013
Old 04-30-2007, 06:37 PM
Re: G Voyager Differential Cover
I still haven't done my homework. Anyway, this morning I had a chance to trace the leak. It looks like it is leaking in two areas : return hose and the differential-half shaft joint. It looks like the oil is coming out from one of the bolts. See http://www.geocities.com/egcentino/c...ansOilLeak.JPG. It is the bolt that is encircled with blue.
Is there a seal there that might have broken? Just want to get an idea before I open it tomorrow.
Thanks for your reply.
