Old 08-26-2006, 09:51 AM
gelcol gelcol is offline
Smile hoe to check the timming belt or remove the side cover does it need to remove the val
got 1992 honda acc. lx need to check my timming belt anyone ? T.Y.
Old 08-26-2006, 11:36 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: hoe to check the timming belt or remove the side cover does it need to remove the val
To physically see your timing belt you have to remove the upper timing cover. To just check and make sure it hasn't snapped, open your oil filler and look inside while someone cranks the engine. If you see movement, the timing belt is still intact.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 08-27-2006, 12:23 AM
I'd try to unscrew the side plastic and it did'nt came off is there a lock or something?
Old 08-29-2006, 10:27 AM
starynight starynight is offline
The valve cover has to come off first. The upper timing cover is locked below it.
