Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-26-2006, 01:29 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Breaking in Head
Hey all, got 2 questions.
1) When I get th ehead installed with everything being new, I figure that has to be a breakin process for it, correct? If so, what would that consist of? Just normal driving, no WOT all the time?
2) These are the cams I'm looking to get next week. Are these good? I see idle would be a little rougher. How would they sound? Anyone else try these?
http://www.mainsitepage.conceptillus...Page/index.htm
Thanks.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-26-2006, 01:48 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Breaking in Head
Nope, no break in. Just make sure its good and lubed up in there before you go all hardcore on it. Be sure to use oil or assembly lube on all the bearing/contact surfaces when you do the reassembly.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-26-2006, 10:49 AM
1996EclipseRS 1996EclipseRS is offline
I would recommend using regular oil as apposed to synthetic as well.
420A
JE Forged Pistons 10:5, Crane Super Street Performance Cams, Crower Connecting Rods, Crower Valve Springs, Port & Polished Head, A'PEXi SAFC II, DigiMoto Datalogger + more, Prothane Motor Mounts, Ebay Header =(, Stock Exhaust, busted driver side window, stolen SAFC(tear), blown tranny
-1984 Mercedes Turbo Diesel 300CD (270k)
-1992 Ford F-150 302 (180k)
Old 09-03-2006, 03:29 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
why is it people use regular oil apposed to synthetic for break it? thanks
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 09-03-2006, 03:48 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Because for break in you want more friction and synthetic has very little friction. In order to seat the rings properly there needs to be some friction. I'm not sure why you wouldn't you wouldn't use synthetic for a head break-in considering nothing needs to be seated...
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 09-03-2006, 05:50 PM
E-Klips E-Klips is offline
Banned
A head doesnt need to be "broke" in. Cams on the other hand do. Just go for a cruise. Keep the RPMs between 2-3k for a good 15-20mins of driving and you are good to go.
As stated before, synthetic oil is very slippery and reduces friction/wear. When putting a new head on, it doesnt matter what oil you use. Synthetic would actually be better for it due to the fact you dont want any friction between the cams and the cam journals seeing there is no bearings.
Old 09-03-2006, 07:24 PM
thanks
1997 Eclipse GS-T
