Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 08-25-2006, 03:49 PM
carb0n03 carb0n03 is offline
1993 lebaron problem
well lets see. This car has had pretty much everything done to it over the past couple years. New radiator, new fuel pump fuel filter among other things. Well i got the fuel pump done a couple weeks ago. Well the car dies. I dont know whats going on i've gone over anything. Its had eight bottles of sea foam through it and everytime i put some through it, it runs like a brand new car. Then after a couple miles it dies. Now if i go real easy on like grandma driving it it'll run good but as soon as i hit the gas even a little bit more it dies.
If anyone can offer any inspiration on what the problem could be it would be much appreciated.
Old 08-27-2006, 01:52 PM
Joric theredbaron's Avatar
Joric theredbaron Joric theredbaron is offline
Re: 1993 lebaron problem
when you got the pump done.. did you replace the fuel filter/s.??
Joric
Friends dont let friends drive imports
Old 08-28-2006, 12:33 PM
yes the fuel filter was also replaced.
Old 08-30-2006, 03:11 PM
Hmmmmm.. head gaskets ok..???
Joric
Old 08-30-2006, 03:46 PM
that i dont know
Old 09-10-2006, 07:19 AM
Old School Man Old School Man is offline
Ok first these cars are great cars and are a untapped jem, in your case I would have the pressure tested on the fuel pump to unsure it is up for it sound like you fuel pump is ither defected from the box or is restricted by bad install........Allso check codes and may have issue with roll over senser being triggered but check pressure on fuel lines first , I put my money there or some how some vacum lines may have been installed wrong setting off the fuel roll over shut off............Old School
