Old 08-25-2006, 12:07 PM
goser goser is offline
Rust control?
Came across this today:
http://www.canadiantire.ca/assortmen...romSearch=true
Also the company website; http://www.counteractrust.com/
Anyone have any input on this? Snake oil?
Old 08-25-2006, 01:20 PM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Re: Rust control?
I had a similar unit on an old Aerostar. I liked it - it worked very well until the unit died(I think) after 7 years. We've always had high mileage cars and didn't see any rust start until around 130k of upstate NY weather. The process makes sense to me. I might try it agin on my next new or newer car. I like the idea of the LED warning lights to let you know it's still working.
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 08-27-2006, 08:48 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Rust control?
Get the rust spray done. Cheaper and will last a lot longer than those elctronic gismos.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-27-2006, 09:44 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: Rust control?
A relative has this on his car, its been seven years since, and it does seem to work. The technology has been used for awhile, so its been around. I have been considering this for a long time, and since the price has gone down a lot, I will be putting this on my truck before the winter.
Old 08-27-2006, 10:35 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Rust control?
those electronic rust proventing systems work well. best to install them on new cars to provent rust later on. they do die eventually though. i just use undercoating in a spray can. its alot cheaper that those systems and it works. i used it mostly on the frame.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 08-28-2006, 02:43 AM
BlazerLT's Avatar
AF -Advisor
Re: Rust control?
The one thing it will do is stop the body from rusting, but everything else will be eaten away.
Best to use something that covers the whole truck and engine instead of just one area.
They are good for areas without any salt, but for anyone with a vehicle exposed to salt every winter, you will see some rust quickly.
Just saw a 2005 Corolla with it installed and the parts of the engine nd some areas are indeed rotting and rusting quickly.
Old 08-28-2006, 04:01 PM
blazes9395's Avatar
Newbie mod
Re: Rust control?
Thats the one most thing I want to stop from rusting- the body.
I never get the engine , transmission, transfer case, sprayed with the rust proofing chemical, to dirty to work on, and, especially in the case of the engine, it looks cleaner, and runs more cooler because it hasn't got a load of rustproofing on it.
What do you mean by engine parts? What engine parts are you referring to that rust?
Old 08-28-2006, 08:31 PM
BlazerLT's Avatar
AF -Advisor
Re: Rust control?
Lots of things, bolts, bracing, screws and washers etc....
The module does not compensate for salt, it only stops normal corrosion from exposure to air and water and such, advanced consition will not be helped.
