Old 08-25-2006, 11:58 AM
bluebuick91 bluebuick91 is offline
91 3.8 air conditioner question
Hi all... the air conditioning pump/pulley is out. It started smoking really bad, and is now really loose, slides in and out when you take the belt off.
My question is, can I buy a serpentine belt for a lesabre without air conditioning, put it on and run the car, bypassing the air pump? One is available, but I am not sure if it can be done...thanks for the help!
Old 08-25-2006, 10:18 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 91 3.8 air conditioner question
Yes, it can and has been done.
Old 08-26-2006, 04:02 PM
can i just put the other belt on or do I have to have the bypass pulley for it? Also, i heard that you can just change the clutch pulley also, is that true and how do you pull it? thanks for your help guys!!
Old 09-03-2006, 03:11 PM
Ncgreasemonkey's Avatar
Ncgreasemonkey Ncgreasemonkey is offline
My buick has the same problem. I found that the clutch has come apart, and the inner half is rubbing around and causing alot of noise. I was trying to remove the clutch and just pull of the loose piece, but found that I didn't have a socket to fit the clutch, what gives?
Old 09-03-2006, 07:59 PM
HotZ28's Avatar
AF Moderator Elite
You need a clutch remover tool simular to this: ToolSource - Product Display
Old 09-08-2006, 11:16 PM
Thanks for the tip Z. Thought that might be the case, I noted the threaded inside of the hub, but wasn't sure if there was a nut holding the center. Kinda looked like it, but I only checked it out for a bit. I'll be headin' down to autozone's lone-a-tool deal tomorrow. Was just gonna put an ac bypass pulley on, but it would appear motormite has scrappped that, 'cause it's on national backorder atm. Guess I'll just go back to plan A
