Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-25-2006, 11:23 AM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
cheap 4g63nt mod
after doing different mods to my 1g N/t (intake,exhaust,headers) i decided there has to be something eles to gain some more HP. So i found some 96 galant 4g64 injectors at my local scrap yard, so i put them in to see if i would get any gain out of them, I noticed a big difference in pick up and pull. So far this has been a nice mod. So hopfully this helps other n/t owners
Old 08-25-2006, 11:26 AM
steviek's Avatar
steviek steviek is offline
Re: cheap 4g63nt mod
what is the size difference?
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 08-25-2006, 12:35 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I don't really understand how this would help you, with your mods you don't require any more fuel that what the stock injectors can provide...
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-25-2006, 12:45 PM
well stock n/t 4g63 injectors are 235cc.... 4g64 injectors from the galants are 300cc injectors.
Old 08-25-2006, 12:47 PM
well IMO i think the injectors add HP i mean it dont take me to long to tack it up at all with the galant injectors. And i feel a hell of alot more pull when driving, i think it was a pretty good mod
Old 08-25-2006, 02:37 PM
jBz jBz is offline
The only thing I could think of is a little bit of power gain. Probably not much, but I would imagine you would feel some more pull because theres a bit more fuel being squeezed in.
Old 08-25-2006, 03:16 PM
steviek's Avatar
yea but more fuel does not equal more power. There is an optimum a/f ratio which your ecu tries to attain, when you add bigger injectors the ecu continues to open up the bigger injectors like it would for the smaller injectors, the only thing is at the same level the bigger injector flows more, which causes too much fuel and the car runs rich. This actually decreases the cars power. The only way tossing in bigger injectors without controlling them could help your car is if for some reason your ecu was calibrated to run too lean and now the bigger injectors by accident are causing better stoichoimetry.
and I know for sure that the turbo ecu's are already running rich (to avoid damage (or so they say).
But if it worked for you good!
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 08-25-2006, 05:18 PM
yeah i completly understand i dont think its dumping in to much more fuel but enuff to see a difference thought
Old 08-25-2006, 05:19 PM
heres a list i found
Non-Turbo 1.8L - N210H Injectors-casting #INP-057 (210cc High Impedance)
Non-Turbo 4G63 - N240H Injectors-casting #INP-059 (240cc High Impedance)
Turbo 4G63 A/T - B390L Injectors-casting #INP-008 (390cc Low Impedance)
Turbo 4G63 M/T - B450L Injectors-casting #INP-009 (450cc Low Impedance)
2G Turbo BlackTops -MDL450 casting #IPN-081 (450cc Low Impedance)
2.4 - MDH275-casting #IPN-065 (275cc High Impedance)
JDM motors that came with the B16G had yellow 510cc injectorsund.
Old 08-25-2006, 05:20 PM
so i went from 240cc to to 275cc
