Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 08-25-2006, 08:28 AM
arbyp arbyp is offline
loss of brakes
I have new brakes all the way around vehicle but a couple of times when I went to apply brakes the pedal went right to the floor, after pumping them up it worked fine for a couple of weeks until it did it again. any help would be appreciated.
Old 08-25-2006, 09:11 AM
KimMG KimMG is offline
AF - Advisor
Re: loss of brakes
There is either air in the system or the master cylinder is failing.
Old 08-25-2006, 05:27 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: loss of brakes
Or you have a leak. Is the fluid low?
Old 08-28-2006, 06:49 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: loss of brakes
Yeah sounds the master cylinder but you definetly want to check out everything the guys posted. Brakes aren't something you want to forget about.
Old 09-01-2006, 06:22 AM
Re: loss of brakes
fluid is up and can't find any leaks, how do you check the master cyclinder
Old 10-11-2006, 08:47 PM
rhandwor rhandwor is offline
Re: loss of brakes
Hold down on the brake pedal does the pedal stay up or go down gradually. Your symptons sound like a master cylinder unless you did brake work recently and didn't bleed properly.
Go to a parts store and purchase a rebuilt unit. This is only if you know to bleed the brakes.
Otherwise go to a good garage and get it done. At some point you will hit the pedal and ram a police cruiser.
This will really make your day.
