Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-25-2006, 12:15 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
S-AFC II Installed
well it was actually very very easy....lol anywayz heres a cuple pics. But now comes the hard part lol.......actually tuneing it....but i gota get it running before i can even do that.
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 08-25-2006, 12:37 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: S-AFC II Installed
Nice nice. Tune that bitch and let me know if it makes a difference so I know whether or not to buy one.
95 Talon TSI AWD
97 Eclipse GST
Old 08-25-2006, 08:38 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
man I'm not trying to be a jerk, but I just don't understand how that's going to make a difference. The car has no extra fuel to compensate.
now - 2000 civic
soon - 2002 is300
Old 08-25-2006, 08:53 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Yeah he is right. My car had safc since I bought it but everything was set to factory. Apparently you can tune it because, there is a minor issue with a/f ratio from the factory(rumor?). But, yeah the afc doesn't really make a huge difference untill you get the bigger injectors going on.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 08-25-2006, 09:06 PM
steviek's Avatar
steviek steviek is offline
factory ecu's run about 14% too rich (on the turbos_) I don't know if its the same for the NT's. But if it is I would take away 14% airflow across the board to optimize a/f ratio. But find out for sure about NT ecus first
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 08-26-2006, 01:24 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
You can tune it without injectors. The stock fuel system can handle more fuel flow. IDK about stock being too rich to begin with. Doesn't make sense. Totally different engine, fuel setup, compression, and ECU. You want the turbo setup to be rich from the factory because then you won't have the possiblity of knock from running too lean at boost.
I've got mine setup so that at idle, the map is turned down, so idle is lower and even fuel consumption is better. Then it climbs up at high throttle and you feel it kick in. Logged and check double time, O2 readings are good at .93 or so, which is near perfect considering I don't have a WBO2. I guess each car is different and the mods on each will change everything else too.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
