Old 08-24-2006, 10:59 PM
roadrunner_70 roadrunner_70 is offline
Send a message via Yahoo to roadrunner_70
4L60E Issues
'93 C1500 2WD, 115K. Transmission was fine. Had oil changed a month ago. Noticed fluid was high(overfilled) on dipstick, but wasn't til transmission started leaking from filler tube, and U joint, that problems developed. When cold, won't engage Rev or Forward. Must rev up to about 2,000RPM. Slips in and out of gear til warmed up. Fluid level is now close to normal, with no burnt smell. Could this be the result of overfilling? Or is this a classic failure of a)pump, or b)torque converter, or c)internal leakage. Any advice appreciated.
Old 08-25-2006, 07:06 PM
maxwedge maxwedge is offline
A990 racer
Re: 4L60E Issues
Overfill will not cause this unless after driving for a while it foamed up then there may be an issue.
Old 08-25-2006, 09:18 PM
Blue Bowtie's Avatar
Registered Offender
Re: 4L60E Issues
What oil was used to refill the trans?
Old 08-25-2006, 10:22 PM
Re: 4L60E Issues
Dexron III was used, I believe. The tranny is in pieces now at the shop. The tech showed me the parts, and nothing was out of the ordinary as far as wear. His best guess is hardened seals that caused a pressure reduction. I had a list of things I gained from this forum, and mentioned a few to him. One was a common weakness in the 4L60E which is the Sun Shell. Mine wasn't that worn, but was beginning to show signs of wear, and given their failure rate I asked for the "Beast" to replace it.TCC control valve bore wasn't bad. Corvette Servo, High Energy clutches, shift kit and all electronics I'm passing on, since it's a V6 and not used for towing or heavy hauling. He agreed on another addition which was the .500 boost valve with the pump rebuild. Master overhaul kit, and sealing rings on the stator. Also a rebuild torque converter. The main solenoid is being replaced too. Is the TCC regulator w/sleeve a must at this point? He mentioned something about PWM(Pulse Width Modulation) and another type of tranny which escapes me, but this is more an issue with one than the other, and mine is the other. Okay, after all that the boss wasn't in and I have to wait til Monday for an estimate. Any guesses? The remove and reinstall alone is $400. My guess is $1200 minimum.
Old 08-27-2006, 09:14 PM
troy1 troy1 is offline
AF -Advisor
Re: 4L60E Issues
93 did not PWM the TCC so the valve hardly ever wears
Old 08-27-2006, 09:27 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: 4L60E Issues
I'd have the valve-body looked over as well. A worn spoolvalve or bore would give a slip until it warmed up. This is a common problem on it's front wheel drive cousin, the 4T60-E. Also, the upgraded servo, clutches, and shift kit are only gonna make the rebuilt transmission stronger AND longer lasting..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-27-2006, 10:12 PM
95silverado 95silverado is offline
Re: 4L60E Issues
I just had mine rebuilt in my 95 extended cab with all the upgrades. It was
a little over $1400. The truck has 194,600 mile on it.
Old 08-31-2006, 11:28 AM
Re: 4L60E Issues
$1900 for rebuild with upgrades. "The Beast" Sun shell, .500 boost valve, rebuilt torque converter, TCC clutch valve. That is steep, but should be solid with the upgrades. 1 Year 12,000 mile warranty. The standard rebuild for this tranny would run about $1600. They blew a brake line testing the truck, and only after I told them I couldn't drive it like that did they agree to get it fixed. I had the fluid changed on this transmission only about a month before it started acting up. Not a flush, but a change, with filter. Might be a coincidence, but I believe that the new fluid in the system might have played a role. Perhaps detergents washing away what crud had built up, but was nonetheless keeping things working. It would appear that seals had deteriorated internally. I'm sure that the overfilling at service didn't help either. If I have any advice for someone in my shoes, it would be to price a rebuild before allowing any shop to dismantle your transmission. They are reluctant to do so, always insisting that it might not need it, but once it's in pieces, what are you gonna do. Even after dismantling, they couldn't tell me what the malfunction was with any certainty. I found a lot of shops would do it for less, and with all the right upgrades.
Old 08-31-2006, 01:02 PM
Re: 4L60E Issues
Who'd you have do it?
Old 08-31-2006, 02:44 PM
Re: 4L60E Issues
Work was done by a local transmission shop. It's a franchise operation. Not AAMCO or Mister Transmission.
Old 08-31-2006, 11:04 PM
Re: 4L60E Issues
WHEW!! Well, congrats and hopefully you'll get a long service life out of it..
