Old 08-24-2006, 10:30 PM
blacksmith76 blacksmith76 is offline
fuel filter won't come off
Anyone know a trick to get a fuel filter off a 95 s-10 2.2? My fittings are rusted so I can't get the filter to turn. Thanks!
Old 08-24-2006, 10:38 PM
Jeepjones85 Jeepjones85 is offline
Cool Re: fuel filter won't come off
Hey If it was me i would spray it with WD-40 let it
Set for a while and try it again... I had to do that
to my S-10 today.
Old 08-25-2006, 01:10 PM
Mango™'s Avatar
Mango™ Mango™ is offline
weld it off, (J/K) Trying prying it off, becareful and dont bend the lines.
Old 08-25-2006, 02:19 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If all else fails put a support behind the nut part of old fuel filter like a a big block and take a chisel or muffler gun and crack the nut part on the old filter.
MT
MT
Old 08-25-2006, 05:49 PM
thanks all! I'm gonna give it another try on Sunday when I have some help. I believe the rust came from the mag chloride they use to melt ice on the roads. I'm gonna pay better attention to the underside of my s-10 from now on! Thanks!
Old 08-25-2006, 09:20 PM
joshmitch05 joshmitch05 is offline
PB Blaster.
Old 08-25-2006, 11:02 PM
PB Blaster?! What is that?
Old 08-26-2006, 08:20 PM
It's a spray-can chemical that loosens rusted bolts/whatever else. Your local Auto shop or Walmart should have it. Just spray the bolts liberally one morning and if you want to, try it in 3-4 hour intervals throughout the day. If, with every attempt, it won't come lose, hit it with some more Blaster. My guess would be the first shot and letting it sit for a few hours would be good enough, or hitting it the night before and going and doing it in the morning.
Old 08-26-2006, 10:44 PM
thanks! I'll look for that!
Old 08-27-2006, 12:03 AM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
You need PB Blaster for everything that is stuck. WD-40 doesn't begin to compare.
http://images.google.com/images?clie...-8&sa=N&tab=wi
Old 08-28-2006, 08:51 AM
jmagerl jmagerl is offline
Just in case you can't get it off, the dealer sells a filter rebuild kit for when you finally have mangled it enough and you finally cut it off out of frustration.
Old 09-05-2006, 06:18 AM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
I just cut the line and put a 150psi rubber hose on it with 4 clamps, hasnt leaked since and its been almost a year of driving on alot of different terrain, rarely any of its flat.
Old 09-13-2006, 03:30 AM
longhairedg79 longhairedg79 is offline
Originally Posted by joshmitch05
PB Blaster.
damend fine stuff there
also try FREEALL
