Old 08-24-2006, 08:01 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Car's running reeeeally rough.
Well, it's that time of the week again. Something else is wrong with my car
So, my starters been fucked since a couple weeks ago, and I just havn't had the money to fix it even thought it's pretty cheap. I go out to my car today, try to start it, and the engine just keeps turning over. Eventually, I get it to start, and my RPM's jump to 2K and stay there. I drive around, and whenever I push the clutch in, the RPM's immediately dive down to 2K. After a while, it goes back to normal.
On a sidenote, we found out that my car was leaking coolant, but it doesn't seem to be leaking it anymore. I'm thinking my water pump might be broken, but who knows. Anyways, help would be much appreciated. Someone save me before I kill my car.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 08-25-2006, 11:38 AM
Re: Car's running reeeeally rough.
Anyone? I also realized that my oil temp. is kinda high. Any suggestions?
Black 1997 3000GT
Old 08-25-2006, 11:45 AM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
could be a few things, the fact that you're idleing at 2k suggests to me wierd shit like a bad MAF, or what's that thing that you 3s guys always have... ETCAS or something, maybe even a bad ecu as well. Are you burning any oil either??? high oil temp + leaking coolant sounds like a gasket/seal problem. Good luck buddy, I just don't know. Stealthee where are you!!!??
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 08-25-2006, 11:53 AM
I asked stealthee last night...and he had no idea. About the burning oil question, what color smoke comes out when you burn oil vs burning water? If I'm right, I think that oil is black smoke and the water is white, but I could have the two mixed up. Anyhow, I'm smoking white.
And rockers mom is smoking hot.
Black 1997 3000GT
Old 08-25-2006, 11:56 AM
sLADe781 sLADe781 is offline
LOL I'm always asking Stealthee through AIM too. Maybe it's an asian thing? Hehe
Old 08-25-2006, 11:58 AM
Igovert500's Avatar
blue + red light magnet
oil is bluish, black is from running rich, white is coolant. I got a few ideas, but I gotta run. I'll write up suggestions when I get back.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-25-2006, 12:10 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
like i said last night in the AFchatroom before you signed off. try adjusting the BISS screw that adjusts the idle, see if you see any noticeable difference.
but what is odd and weird is that it idles HIGH at 2k rpm!@#@!@
are you getting a CEL?
i would check the normal stuff like MAF, ISC, BISS.
i'm sure Geoffykins will chime in with some moral wisdom when he gets back from running
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-25-2006, 10:06 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
IAC? That's always been common with these cars, it'll make your idle do weird things. You positive the smoke is white? the difference between white smoke and the bluish smoke oil makes isn't much.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 08-25-2006, 10:55 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
I got white grey smoke going on. LOL When I start the Stealth its not only profusely burning oil but burning water too.
Old 08-26-2006, 04:20 AM
Linebckr49's Avatar
VSS and thermostat? maybe not thermostat. if burning water, then what's teh solution?
93 3000GT base
Old 08-26-2006, 04:39 AM
Stealthee's Avatar
Bad rings and anything from cracked head to a numersous amount of other things... The way it acted the day it broke it seemed as if it ate a valve. All I know is its losing water and none is leaking and none is in the oil pan.
Old 08-26-2006, 04:53 AM
Linebckr49's Avatar
so that's why your car has been sitting for the past 6 months!
/thread hijack
93 3000GT base
Old 08-26-2006, 11:24 AM
Stealthee's Avatar
Umm duhhhhhh.
Old 08-26-2006, 12:02 PM
Igovert500's Avatar
OK, so here's what I theorize. The Fast Idle Air Valve is the part of your throttle body with coolant lines running through it. The fast idle air valve is open when the throttle body is cold and bypasses enough air around the butterfly to increase the idle speed to 1500-2000 rpm. With the coolant lines connected and flowing properly, the valve warms up pretty quickly and closes, and the idle speed drops to normal. Now the problem is, you said you were burning/losing coolant. How much? If the FIAV isn't seeing the coolant temp increase it could be staying open the entire time.
Run the car, is the lower part of the throttle body cool or hot to the touch? If cool it suggests the valve is staying open. Check your coolant. Make sure a) it is at the right level, b) it isn't mixed with oil (oil would be milky and have bubbles) c) make sure the flow of coolant isn't blocked. d) make sure the coolant lines running to the TB aren't broken.
Obviously the high idle may also be caused by a huge leak in the plenum or something like that. Might also not hurt to check your timing. But high idle and coolant issues make me think FIAV. I don't think it's broken, I think that the lost coolant is the culprit. You find where you are leaking/burning coolant and I think this will solve itself.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-26-2006, 12:50 PM
Linebckr49's Avatar
umm...wow, Geoff. that sounds pretty good. have you been reading the service manual from front to back? i've never heard of the FIAV.
definitely a logical problem with his 2 symptoms.
i guess i need to do more reading.
93 3000GT base
