Old 08-24-2006, 04:36 PM
1986TBIRDV8 1986TBIRDV8 is offline
Inline fuse keeps blowing when I replace it
Ok, here is the deal.
I was running my 15" Kicker comp with my 1000 watt amp for about an hour straight. (it was a long drive )
My inline fuse blew and I replaced the 8 gauge power cable with 4 gauge cable and the 50 amp fuse with a 80 amp fuse.
The fuse blows after about 10 seconds.
It keeps on blowing everytime I replace it.
Any ideas? Thanks.
Old 08-24-2006, 06:49 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Inline fuse keeps blowing when I replace it
Is the headunit turned on while you're doing this or is everything off?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 08-24-2006, 06:56 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
either the power wire is shorted somewhere or your amp is drawing too much power for some reason
Old 08-24-2006, 07:25 PM
When I replace the fuse, I turn on the HU and everything (amp and sub) fires up. After about 10 seconds, the power cable fuse blows and the amp and the sub shuts off but the HU is still playing. I can't for the life of me figure out what is wrong. I just replaced the power cable with brand new 4 gauge wire so that is ruled out. What would cause the amp to draw excess power? Thanks for the replies
Old 08-24-2006, 07:57 PM
sr20de4evr's Avatar
But it doesn't blow if you leave the headunit (and therefore, the amp) off?
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-24-2006, 09:37 PM
If I leave the HU off the fuse won't blow.
Old 08-24-2006, 09:42 PM
sr20de4evr's Avatar
Well that rules out a short in the power cable, and normally when an amp's PS is blown it will kill the fuse instantly, whether the amp is on or off.
Do you have a DMM?
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-24-2006, 11:13 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
use a bigger fuse??? lol
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 08-25-2006, 12:54 AM
Unfortunately, I don't have a DMM. And if I were to use a bigger fuse, I would run the chance of a fire.
Old 08-25-2006, 07:59 AM
stone_mound_camaro's Avatar
stone_mound_camaro stone_mound_camaro is offline
i promise you wont...you have a bigger amp...1000watts draws a lot of amps...you need at least something more than 100 for a fuse
car audio guru...
Old 08-25-2006, 12:42 PM
I was running that same amp with 8 gauge power cable and a 50 amp fuse for about a year so I don't think a bigger fuse will solve the problem.
Old 08-25-2006, 05:18 PM
Audio Guy
it's possible that's all the current the 8 Ga power wire was letting thru, but not likely. More likely you had weak connections before if this is truely your problem
Old 08-25-2006, 09:43 PM
I don't think I have ANY weak connections. I already double checked them all. Having no bass in my car blows. A bad amp is all I can think of.
Old 08-25-2006, 09:47 PM
Also, I replaced the fuse in the 8 gauge cable PRIOR to changing the cable and it still blew.
Old 08-26-2006, 09:05 AM
Audio Guy
then it's definitely time to have the amp checked
