Old 08-24-2006, 03:03 PM
wakeboard1026 wakeboard1026 is offline
Send a message via AIM to wakeboard1026
stock vr4 ic piping diameter?
whats the stock ic piping diameter on the vr4's? i would say close to 2" from comp pics but i cant even find any 2" ic piping on ebay.
Style like Morphius289... lol
Old 08-24-2006, 03:10 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: stock vr4 ic piping diameter?
o. O.... do i smell TT conversion?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-24-2006, 04:20 PM
AutostradaVR4 AutostradaVR4 is offline
2" Od
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 08-24-2006, 04:53 PM
ur a good smeller linebckr haha. im going to go with a fmic and want to make and fit all the piping myself so i reckon ill go with 2.5" (or if i could find 2") then y connection into the ic then out w/ 3" to the bov and intake mani
wtb: 94-97 vr4 ecu, front engine bracket
Old 08-24-2006, 05:00 PM
Igovert500's Avatar
blue + red light magnet
What turbos are you using, becuase 9bs and a huge FMIC don't necessarily mix well IMO.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-24-2006, 05:20 PM
ya im using 9b's but in the future ill probably upgrade and i dont want to have to constantly upsize the ic and piping. iv talked to some people on 3si and im going to get an ebay core 12x24x3" and that should do fine with a DECENT psi drop and good flow characteristics. but im 17, hence, open to opinions (learning as i go) so thanks for the heads up. some other people told me right bfore i was going to buy a Huge fmic haha
Old 08-24-2006, 06:06 PM
Linebckr49's Avatar
don't forget the wiring harness from that same year VR4 ecu. not sure if different year wiring harnesses are interchangeable or not.
wiring harness, or you can make your own low impedance injectors. can't remember what other connectors you'll need, but i'm sure the vr4 harness would tie up any loose ends.
93 3000GT base
Old 08-24-2006, 07:05 PM
Igovert500's Avatar
For the sake of cost, I'd go used and modified DSM sidemounts and used vr4 piping, or just get a universal pipe kit on ebay and cut what you need.
I'm tryin 2 find a thread I think you should read, but the search features are really slow right now, and I'm in a rush, so I'll try and find it later.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-24-2006, 07:45 PM
Knight2040's Avatar
Knight2040 Knight2040 is offline
Send a message via AIM to Knight2040
i'm gonna buy solid motor mounts pretty soon, but i dunno if my 1st gen motor mount will work for you. I also have a stock vr4 bov and blitz boost gauge if u need them lol
1991 Mitsubishi 3000GT VR4 Twin Turbo- Forged Ross Pistons,Forged Crank,Forged and Shotpeened Rods,Stillin DP,K&N FIPK,Greddy Type-RS BOV,Magnacor Wires,Aluminum Y-Pipe,EGR Blocked,All Gutted Cats,Greddy Turbo Timer,Blitz Boost Guage,Autometer A\F Guage,Solid Shift Bushings,Red Top Batt,ACT 6 Puck Clutch,Free Boost Mod,99 Front End Conversion
Old 08-24-2006, 07:58 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
pssst...go TD05...
Either that or get some GT-368's. 9b's are tiny.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 08-24-2006, 08:49 PM
funny u said that morhphius cuz i had only seen 9b's in pictures and when i got them i thought someone was pranking me but heck im a lifeguard and on a budget but if u want to donate to the td05 fund.... haha. some others had suggested dsm side mounts igo but some guys with stock vr4's use the ebay core and ic piping, and im basically going to b the same as them. and im not gonna lie, i 78.1% want a front mount because it will look nasty on the front of my car.
