Old 08-24-2006, 12:53 PM
fajita23200 fajita23200 is offline
Thumbs up Re: Abs problems
Hi, I know I've asked for help about this issue a couple of times before. It's been quite a while since I've logged on or posted here. I just wanted to let people know. I've found a posible solution to the multiple complaints about the cavy a.b.s. issues I've read about over the last couple of years. I'm not very knowledgeable about cars or how they work. That's why I come here. My roomate and friend of 15 years was a mechanic for about 12 years. He informed me of a common problem with front wheel drive G.M. cars. The ring gear around the axle, sometimes has cracks in the teeth, or has broken teeth. I never have completely understood all he told me. But, it has something to do with the a.b.s. speed sensor not connecting with these teeth sometimes. Or something to that effect. I hope he was right and this has been helpful.
This above all:To thine own self be true,and it must follow,as the night, the day,thou canst not then be false to any man.(William Shakespeare)
Old 08-24-2006, 01:44 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Abs problems
The broken ring was more of a problem on some fords on some models.
Abs problems come in all different kinds sises and shapes and forms..
That is why they makes ABS scanners to check them out.
MT
MT
Old 08-25-2006, 02:04 PM
Re: Abs problems
MT
Yes, they make abs scanners to check out problems. But, when my cavy was diagnosed with the same problem twice. I had a brand new wheel speed sensor replaced at no cost. It did not help at all. I hope this info helps some people. Because, I've been told it is an all to common problem with certain year G.M. year cars. Thanks for the reply...
Old 08-25-2006, 02:31 PM
MT-2500's Avatar
AF - Advisor
Re: Abs problems
The scanner will show you the problem.
But codes do not say repace sensors.
They point you to the problem and say check it out.
MT
MT
