Old 08-24-2006, 01:31 PM
joeuser742 joeuser742 is offline
99 Transmission work
Well, I finally had some time to work on my transmission. I did some research and my problem is pointing to the valvebody. I was having 1-2 shift problems (soft, hard, and other; and yes I checked the wiring before I did this). I removed the valve body, no problem, without dropping the transmission. I did all the work from under the hood. While briefly testing, I did come across a sticky valve, which was the whole reason I'm doing this. I'll have to take some pics of the work I do on the valvebody.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
Old 08-24-2006, 03:02 PM
phil-l phil-l is offline
Re: 99 Transmission work
Please share some pictures!
You were able to get to the valve body from under the hood - without going under the van?
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 08-24-2006, 03:41 PM
Yup, I think that it might have took a bit longer the way I did it, but there was alot more room. I removed that windshield wiper assembly (I think it's called the cowl), airbox, battery, and battery holder, and disconnected all the trans plugs and anything else in the way. Then, I used a jack (with some wood) to jack up the transmission, and removed that trans bracket that was blocking the side pan. Took the side pan bolts off, took it out, then unbolted the pump assembly and valve body. There were some bolts that had to stay in otherwise the pump assem and the valve body would separate (probably a bad thing to do). After getting all the bolts out, it came right out. Now, I'm just waiting for the tool to hopefully fix this problem.
Repairs
Mods/upgrades
Repairs
Old 08-24-2006, 06:24 PM
12Ounce 12Ounce is offline
While you are in that area, I strongly recommend you rebuild the 1 - 2 servo on rear of tranny.
Old 08-24-2006, 09:57 PM
Already did that, got the revised parts also. Only problem I have is the new spring is much bigger and is difficult to get in and probably impossible to get out without moving things around.
Repairs
Mods/upgrades
Repairs
Old 08-25-2006, 08:09 AM
Hmmm ... didn't know about a "new" spring!
Old 08-25-2006, 10:06 AM
These are Sonnax parts, not OEM. They seem to have many fixes for the AX4S. Check out their website, it's very informative. Here's a few links..
http://www.transmissionspecialty.com...B/AXODE_VB.htm
http://www.transmissionspecialty.com/parts/DM/AXODE.htm
Main website - http://sonnax.com/
Repairs
Mods/upgrades
Repairs
