Old 08-23-2006, 09:16 PM
grn92rt's Avatar
grn92rt grn92rt is offline
electrical problem 92 stealth rt
i just bought a 1992 dodge stealth rt and i have a couple of problems. dunno if they are related.
First of all the stereo(stock), and the a/c unit don't save the settings when the car turns off.
Second - the dom lights, door lights, trunk and hood lights don't turn on at all.
third - headlights don't go down when i turn off the engine before turning off the lights.
i checked all the fuzes and they all look ok. are there any wires i should check? i have no idea what to do
Old 08-23-2006, 09:17 PM
3kvr4's Avatar
3kvr4 3kvr4 is offline
Send a message via AIM to 3kvr4
Re: electrical problem 92 stealth rt
check with an open volt circuit
Old 08-23-2006, 11:20 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
1) the stereo(stock), and the a/c unit don't save the settings when the car turns off.
2) the dom lights, door lights, trunk and hood lights don't turn on at all.
3) headlights don't go down when i turn off the engine before turning off the lights.
1) so you have the digital climate control? not sure why the settings aren't saved in the a/c, radio. only way settings would NOT be saved is if the battery were disconnected for a few minutes. i would start there, make sure battery terminal connections are clean adn tight.
2) so you've checked the fuses in the cabin by the drivers left foot? there are also fuses under the hood next to the passenger headlight. i would also check the plug connections for those lights (that is, the connectio in the door, in the trunk, the hood, and dome. while you're in there, check the bulbs. HOWEVER, since all those lights aren't working at the same time, that points to one problem somewhere. fuse, relay, or maybe ETACS system...maybe.
3) this is normal. if you have the lights on (popped-up), and turn the car off, the lights go off but remain in popped position. to make them go down, simply turn them off using the twist switch on the steering column before or after turning the car off.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-24-2006, 08:30 PM
grn92rt's Avatar
i fixed the interior lights problem. the "room" fuse was loose in the socket and that's why the interior lights were not on.
I'm still having a problem with the stereo and a/c not saving the settings though
thanks for the help guys
Old 08-24-2006, 08:42 PM
3kvr4's Avatar
Well there is something wrong with the cars memory, check battery cable. I dont know which is the memory cable on this kind of car
check these wires from stealth316.com
http://www.stealth316.com/2-3s-stereo-connectors.htm
Old 08-24-2006, 08:43 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Its a fuse. All those porblems are related. Check them all.
Old 08-24-2006, 08:45 PM
3kvr4's Avatar
ya fuse 19 for yor stereo
Old 08-25-2006, 12:30 AM
Linebckr49's Avatar
i just recalled, there IS a fuse in the back of the stock stereo. you might check it. you have to pull it from the console: with flat head screwdriver, pry out the plastic surround, then there are 4 screws that hold the radio in.
....however, i'm sure its all related and not specific little problems in each area.
93 3000GT base
Old 08-25-2006, 11:40 AM
2old 2old is offline
Personally I think someone was screwed up the wiring in the ingition or center console and it powering the stereo and climate control off the switched lead instead of the constant power lead.
Unfortunately I can't help you there because you will need to trace the leads from the ignition to the stereo and then find out what happened to the constant power lead (bad aftermarket alarm install?)
Old 08-25-2006, 05:14 PM
Stealthee's Avatar
trust me, it is DEFINITELY a fuse. In the fixing of a wrecked 92 RT I ran into the same issues. The lights would only work when the car was started, the radio wouldnt come on, the interior lights and buzzer didnt work, the DCC wouldnt hold memory, nothing. I traced, traced, traced and could find nothing wrong. I sat up on 3si for 6 hours searching one night till I finally figured it out. It had to do with the IOD plug-in in the underhood fuse box. It wasnt making full connection.
There are a few different fuses that could blow to cause those issues too though. One is the battery fusible link underhood. There are a few in the cabin fuse box as well. Thats why I said check EVERY fuse.
Old 08-25-2006, 05:32 PM
What bugs me is if it was a fuse then the radio should not come on at all... Not just that the memory was being erased...
Mind you I don't use a stock head unit and aftermarket ones don't power off the switched power.
Old 08-25-2006, 05:36 PM
Stealthee's Avatar
Then you have it wired wrong. The yellow wire on the aftermarket headunit is the 12v constant. The red is the accesory switch. If you reverse those then it wont turn off when you shut the car off.
Old 08-25-2006, 10:40 PM
grn92rt's Avatar
i'll check the battery fuse tomorrow. i'm also installing an aftermarket deck with amp and sub from my old car. i'll get back to you guys tomorrow. thanks
Old 08-26-2006, 03:56 PM
grn92rt's Avatar
ok... i installed the sound system and now the a/c unit doesn't start automatically when i turn the car or ignition on... which is good. the deck though still doesn't remember the presets but i'm ok with that.
thanks for the help
Old 08-26-2006, 06:09 PM
thanks for the help
You should find the constant 12V and see if it's wired into the head unit... It still sounds like the head unit is being powered using the switched lead...
