Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 08-23-2006, 08:43 PM
DavidChen DavidChen is offline
Exclamation 98 Nissan Altima can't open trunk
Hi there,
Need your help. I have a 98 Nissan Altima. I can't open the trunk either by pull the handler or use the key. I try WD 40. It won't work.
Any suggest?
Thanks in advance.
David
Old 08-24-2006, 06:46 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: 98 Nissan Altima can't open trunk
Well if the manual handle isn't working you have to remove the whole locking mechanism. From what I can remember, I think the thing that turns with the key pulls a string that yanks the locking teeth and releases the hold. Try turning the key while inside the key hole and try lifting the trunk up. If your problem is just starting it should work. I think it's worth a try.
Good Luck.
Old 08-24-2006, 06:27 PM
94altimase 94altimase is offline
Before you go disassembling the tumbler mechanism, try ditching the WD-40, which, in a situation like this only makes your problem worse, and go pick up some Tri-Flow or the like, and give that a shot. Hope it works for you.
Old 08-24-2006, 08:23 PM
cszakolczai cszakolczai is offline
If the key isn't working manually, than it means that something came undone, or broke, we have a bunch of situations like this come into our shop, but there all unique so its hard to diagnose and tell you what your problem, without seeing it.
Chris
Old 08-24-2006, 09:55 PM
white97altimagxe white97altimagxe is offline
Send a message via MSN to white97altimagxe
Maybe try a rust & degunk spray,something like liquid wrench, when my hatch stuck on my Cherokee, it free'd it up anof that I could open it with the key, thou I had to turn it a little harder then I liked.
But it worked
